adding a mA meter to the Kaiju
Larpy · 9845
Offline Larpy
on: December 04, 2020, 12:14:24 PM
I love the idea of adding a couple of mA meters to my Kaiju, but there's not much room under the chassis.  If I were to remove the input pots, is there a way to install meters in their place, or is that spot too sensitive in terms of picking up noise from the cathode?
Larry
Reply #1 on: December 04, 2020, 01:22:32 PM
You can drill holes in the wood base to add meters.
Offline Larpy
Reply #2 on: December 04, 2020, 03:40:22 PM
Better to place them in the middle of the wood base than where the input pots are?
Larry
Reply #3 on: December 04, 2020, 04:37:13 PM
If you are comfortable enlarging the holes in the chassis where the pots are, you could probably do that.  You'd have to relocate the pots or eliminate them from the design.
Offline Larpy
Reply #4 on: December 11, 2020, 08:28:12 AM
I added a couple of meters.  Pretty straightforward procedure.  Now for one last question:  both channels of my Kaiju have 72 mA of current going through the cathodes.  I assume that as the tubes age, the mA measurement will go down(?). At what point should I become alarmed and think about getting replacement tubes?
Larry
Offline johnsonad
Reply #5 on: December 11, 2020, 09:03:26 AM
Nice job Larry! That looks great and a really nice looking build!
Reply #6 on: December 11, 2020, 11:17:38 AM
There are many ways a tube can fail. But if it is simply worn out, the cathode loses emission. An often used criterion is when the transconductance drops to 70% of new. For Kaiju, that amounts to about 4mA reduction in current. This is a small change and hard to see on a meter! Even worse, it's sensitive to power line voltage - a 5% change in the power line has the same effect as a 30% change in transconductance.
The reason it's so small is the self-adjusting nature of cathode resistor bias.
Reply #7 on: December 11, 2020, 12:01:49 PM
I have some very dead 300Bs that still draw about 70mA, it can be pretty tough to tell in a Kaiju!
Offline Larpy
Reply #8 on: December 11, 2020, 04:09:51 PM
So the appeal of adding meters is mostly cosmetic?
Larry
Offline Larpy
Reply #9 on: December 11, 2020, 04:14:00 PM
Thank you, Aaron.  I still plan on springing for the Takatskis you recommended.  A matter of when, not if.
Larry
Online 2wo
Reply #10 on: December 11, 2020, 04:33:43 PM
It may be mostly cosmetic but they sure look good...John
Reply #11 on: December 11, 2020, 05:24:39 PM
Yes.
Offline Natural Sound
Reply #12 on: February 21, 2021, 01:31:57 PM
Yes.
Is that true of the MonAmour 2A3 as well or is the meter more useful in the 2A3 topography?
Reply #13 on: February 21, 2021, 03:20:17 PM
The MonAmour has a switch which changes the 2A3 plate current, and in the high-current mode it requires a modern 2A3 with higher plate dissipation rating than old-stock 2A3s. So the meter indicates the current to help prevent accidentally risking older tubes.
Reply #14 on: February 21, 2021, 03:48:14 PM
Thanks for the explanation P.J. That is a very useful feature indeed. You guys always think of clever stuff like that.
