Bottlehead Kits
Crack
Loud buzz in Right Ear and static in left
shoto1699
1699
shoto1699
Newbie
December 21, 2020, 09:12:09 PM
So my Bottlehead Crack has the right voltages but there's static coming through my left ear's headphones and a loud buzz in the right. It was working fine earlier but when I turned it off later on and turned it back again it came up but only went away after my monitor shut off for a second and then came back later on. Any ideas? I reheated everything already. The buzz came after I reseated the tubes again.
Last Edit: December 21, 2020, 11:32:10 PM by shoto1699
Paul Birkeland
Global Moderator
Hero Member
Re: Loud buzz in Right Ear and static in left
Reply #1 on:
December 22, 2020, 05:23:15 AM
Can you post photos of your build?
Generally this kind of issue would be a loose solder joint in the amp, and often time we find that new builders are a little timid when it comes to applying adequate heat to get the solder to flow out all the way.
shoto1699
Newbie
Reply #2 on:
December 22, 2020, 07:31:17 AM
https://imgur.com/a/Trp07ac
Jameson
Intern in Chief
Administrator
Sr. Member
Reply #3 on:
December 22, 2020, 08:53:20 AM
Might not be related but I'd pick up one of those ALPS PCBs on eBay instead of soldering to the potentiometer pins like that. Much easier and more reliable.
Jameson O'Guinn
Managing Partner
shoto1699
Newbie
Reply #4 on:
December 22, 2020, 09:34:35 AM
Good idea.. it was pretty hard to solder it but I ended up getting it done. I'll check it out
Jameson
Intern in Chief
Administrator
Sr. Member
Reply #5 on:
December 22, 2020, 10:21:18 AM
Here's a recent thread on that PCB:
https://forum.bottlehead.com/index.php?topic=12909.0;topicseen
Jameson O'Guinn
Managing Partner
Paul Birkeland
Global Moderator
Hero Member
Reply #6 on:
December 22, 2020, 12:00:21 PM
One black wire on your headphone jack does not look to be captured by solder. If your iron has a temperature adjustment, I would turn it up all the way. I would also trim back any leads that are poking out.
Bottlehead Kits
Crack
