One last Voltage question
ryburdman · 7500
Offline ryburdman
on: February 25, 2021, 10:27:51 AM
One last question again thanks for all the help.
My voltage reading on 44 and 45 are also different than the manual
44 80v
45 80v
Looking through the forum this seems to be fairly common but its enough different from the manual I thought I should ask. All 4 LED's light up and everything else tests in limits
Ryan Burdick
Reduction/Crack/Aune X1s/RebelAmp/6xx/Mangrid Tea/Tin t2
Online Paul Birkeland
Reply #1 on: February 25, 2021, 12:15:00 PM
I would let the tubes run in for 50 hours and check that again. Those will likely lower with some burn in time.
Offline niceguyjml
Reply #2 on: March 21, 2021, 08:13:38 AM
"Run the Amp" like leave it turned on but no RCA in/out put?
Reply #3 on: March 21, 2021, 09:10:37 AM
You can have the cables hooked up.  This is generally a good idea with the inputs at least.
