Moreplay- illustrated cautionary tale
Doc B. · 25158
on: February 25, 2021, 01:43:35 PM
When you get to the step where you cut a 5 terminal strip down to a 3 terminal strip to mount next to the power inlet don't use your Xcelite side cutters...use some proper diagonal pliers.
Offline Thermioniclife
Reply #1 on: February 25, 2021, 02:34:07 PM
I hate when that happens. If no heavy diagonal cutters I score a line with an exacto knife 4 or 5 times and snap off with a pair of pliers.
Then a little touchup with a sanding block. I hate breaking tools. I still have a pair of Thomas and Betts crimpers that I bought in 1983 and crimped countless thousands of connections when I was a car stereo installer. They have quite a patina on them but work as they did when they were new. Limitations.
Reply #2 on: February 25, 2021, 04:00:37 PM
I did the same damn thing a couple years ago putting together a BH kit!  It's a lesson that only needs to be taught once.
Offline AB2KH
Reply #3 on: February 26, 2021, 11:06:40 AM
Doc,
That comes from the death grip you use on the throttle of your race bike.
Chris/AB2KH
Reply #4 on: February 26, 2021, 05:24:53 PM
For what it's worth, I use these professionally every day and sometimes abuse them horribly like  gnawing my way through 30amp power cables. Never had one break...John
Reply #5 on: February 27, 2021, 05:38:51 AM
Obviously you're not trying hard enough.
Offline patrick620
Reply #6 on: March 02, 2021, 05:25:46 AM
I used a Dremel and a mini cut off wheel.
Offline Overthehill
Reply #7 on: January 08, 2022, 01:02:39 AM
Yea these cutters are for small wires But from my experience from WAY BACK I think xcelite tools use to be guarantied for life.
Offline thibodeaux
Reply #8 on: September 23, 2022, 08:00:19 AM
One more (obvious) tip - make sure you pay close attention to the orientation when cutting this. I made the mistake of cutting off the wrong side, and had to order a replacement. It doesn't fit both ways!  :o
Offline hmbscott
Reply #9 on: March 13, 2023, 03:54:49 PM
@thibodeaux, I did the same damn thing!
Scott
