Speedball upgrade led light not on .
stanmar224 · 3458
Offline stanmar224
on: April 04, 2021, 01:26:53 PM
So i have Crack 1.1 in full functional condition, then i went for Speedball upgrade . So the problem is one of the red led lights not turning on (D1 B side ) when i do a test after soldering first board to the amp . All voltages and resistance are ok and are same as in the instructions. Not sure what is wrong cause i made absolutely sure all solder points are good . Anyone know what's going on ? Thx
Reply #1 on: April 04, 2021, 03:37:33 PM
Can you post the voltages you have on terminals 1-10?
How about also posting some build photos?
Offline stanmar224
Reply #2 on: April 26, 2021, 06:35:04 PM
sorry for taking so long i was really busy.
here are the voltages for terminals 1-10
1. 81.7
2. 174
3. 0
4. 174
5. 62
6. 0
7. 106
8. 0
9. 94
10. 0
Reply #3 on: April 26, 2021, 06:40:38 PM
Is this on the small or the big board?
Offline stanmar224
Reply #4 on: April 26, 2021, 06:46:21 PM
its on terminals that are on the bottom , ( closer to volume adjuster)
Reply #5 on: April 26, 2021, 06:47:38 PM
So the smaller PC board?  Can you post a couple of photos of the board (top and bottom)?
Offline stanmar224
Reply #6 on: April 26, 2021, 06:49:18 PM
wait were you talking about board that comes with speedball upgrade or just those 1-10 terminals on the bottom of the amp ??
Reply #7 on: April 26, 2021, 06:53:43 PM
The Speedball upgrade comes with two green PC boards with white text.  The stock Crack has no PC boards.  One is small and sits over the 9 pin 12AU7 socket and one is larger and sits just forward of the octal 6080 tube socket.
You have said you have a D1 LED out, but there are four D1 LEDs out.  Which board is it on?  Can you post photos of the top and bottom of the PC board with the LED that's not lighting up?
Offline stanmar224
Reply #8 on: April 26, 2021, 06:58:19 PM
ok got it . cause you wanted voltages for terminal 1-10 so i thought it was for crack it self . I only installed 1 crack upgrade board cause in manual it said not to proceed if any LEDs are not lighting up. one sec im trying to see how to post pics here
Reply #9 on: April 26, 2021, 06:58:55 PM
Ah, excellent, you just have the small board in.  That will make things quite a bit easier.
Offline stanmar224
Reply #10 on: April 26, 2021, 07:07:49 PM
Here
Offline stanmar224
Reply #11 on: April 26, 2021, 07:10:49 PM
Its not letting me post more then 2 pics at a time
Reply #12 on: April 27, 2021, 04:50:52 AM
You have a backwards transistor on your PC board.
« Last Edit: April 27, 2021, 05:12:51 AM by Paul Birkeland »
Offline stanmar224
Reply #13 on: April 30, 2021, 08:50:59 AM
Which one ?
Offline stanmar224
Reply #14 on: April 30, 2021, 08:58:28 AM
Oooh wait i see it . Its that little black one . OMG im so stupid.
