My Tang Band W8-1772 Build
JimOfOakCreek · 36783
Offline JimOfOakCreek
on: December 08, 2010, 09:51:13 AM
I am the process of completing a Full Range speaker project using the Tang Band W8-1772. I haven't installed the port tubes yet but the bass response is already impressive. Using test tones from Bass Mekaniks I am able to get down to 44hz with no port tube! The speaker has a rising top end response which needs to be tamed with a simple BSC circuit. They are quite bright straight out of the box. It's amazing that an 8" full range speaker can have such a strong treble response. Imaging and detail is excellent. Efficeincy is rated at 95db/1w. I highly recommend this driver to any potential DIY enthusiast.
« Last Edit: December 08, 2010, 09:53:35 AM by JimOfOakCreek »
Reply #1 on: December 08, 2010, 11:07:25 AM
Jim,
Very nice work!  I have heard a number of speakers using the Tang Band drivers (designed by Jim Griffin) but they were not this sensitive.  The bass was beyond impressive for the driver sizes I heard.
Reply #2 on: December 08, 2010, 01:00:07 PM
Funny, I was just looking at those drivers.
Those look real nice...John
Offline Thoburn
Reply #3 on: December 08, 2010, 03:00:23 PM
Nice. I love building speakers. I seem to frequently find myself wondering about my next build.
What plans did you use? Is it a bass reflex or maybe a transmission line? Just for the fun of it, try listening to them without a BSC by taming the raising high frequency by not listening on axis. I am using a Lowther DX4 8 inch driver in a back loaded horn. I have also had them in a mass loaded transmission line design using a BSC that was made with high quality components. I prefer the horn cabinet without any BSC.
Dynavector DV-20X2L > VPI Scout II > Musical Surroundings NovaPhonomena
Mac Mini > USB DACiTx
Stereomour > Lowther Medallion DX4 and Rythmic Subs
Monster Power HTS3600
Offline mp9
Reply #4 on: December 08, 2010, 03:01:17 PM
They look nice, so why did you choose the W8-1772 over a W8-1808 for the type of enclosure you're doing?
Reply #5 on: December 08, 2010, 03:46:14 PM
The 1772 works well in a smaller box than the 1808 requires. My goal was to build a conservative appearing speaker with a high WAF.
Reply #6 on: December 08, 2010, 03:49:55 PM
It's a bass reflex design. My design is based on design recommendations from posts by Bob Brines. He recommended a BR 40L box with a 3"X6" port.
Reply #7 on: December 08, 2010, 05:09:23 PM
You've got me thinking. The whole point of FR speakers and SET amps is 'simpler is better' - 'less is better than more'.
I love the dtail I am currently hearing. I am going to try listening off axis with no BSC.
I like your idea. Thanks.
Offline Wanderer
Reply #8 on: December 09, 2010, 05:24:05 AM
I have been looking at these Tang Band as well.
Any thought on doing a passive line level BSC between pre and amp ala Sexy speaker?
Kevin R-M
Reply #9 on: December 09, 2010, 07:03:50 AM
Yes, I've been considering that approach as well. That makes a lot of sense in that it keeps the electronic voicing confined to the electronic amplification system. I also like the idea of having the BSC outside the enclosure whether it's between pre and amp or a 'conventional' BSC.
However, at the moment I've become enthusiastic with alternative/simpler approaches to voicing the speakers without circuitry. It fits my newly adopted audio philosophy of less circuitry is better than more.
Out of the box the W8-1772 have a rising top end. This is actually a good thing because it's easy to deal with. It's better to have too strong a high end than no high end. You can deal with a strong high end through various means.
These are very bright speakers on-axis with no BSC. I am amazed that simply listening to my speakers off axis solves the brightness iscue with no circuitry. The detail is amazing without being grating.  I'm going to audition that approach for a few weeks.
Offline howardnair
Reply #10 on: December 09, 2010, 07:22:59 AM
jim --very nice -owning 4 pairs of speakers --3 are diy-jericho horn--a electrovoice baronet--both employing the fostex 208 ES -and ribbon tweeters--the 3rd are 4 ft monsters using 15inch and 12 inch EV and coral full range speakers with also a ribbon tweeter--love full range speakers  --no crossover except for the tweeter--i tried with and with out crossover- prefer without-now you have me thinking about doing something with the tangband---somebody tell me what is a BSC--i suspect it is a crossover
Reply #11 on: December 09, 2010, 07:40:58 AM
BSC = Baffle Step Correction. It's a circuit between the amp and the speaker that corrects for the beaming of mid-high frequencies off the speaker baffle. The baffle acts like a reflector which focuses those frequencies forward. Low frequencies are omni-directional and do not get beamed.
The effect increases mid-high frequencies about 3db or more.
A Baffle Step Compensation circuit reducies those frequencies by 3db or more. It is usually incorporated in the crossover circuit with a typical 2 or 3 way speaker.
You can use that same circuit to tame a bright speaker.
A better explaination and a calculator can be found here:http://diyaudioprojects.com/Technical/Baffle-Step-Correction-Circuit-Calculator/
« Last Edit: December 09, 2010, 07:43:49 AM by JimOfOakCreek »
Offline Maxwell_E
Reply #12 on: December 09, 2010, 12:18:51 PM
Just curious, what difference does it make when you rotate the speakers in rather than out?
Max Tomlinson
SEX amp, Tode guitar amp
Reply #13 on: December 09, 2010, 12:30:12 PM
In theory - :^) - it compensates for off-center listening. When you move to one side, the nearer speaker takes precedence due to earlier arrival, but you are more on-axis with the far one so it takes precedence due to being louder in the treble. With luck those effects cancel out. (Without luck, they just confuse your ears!)
Reply #14 on: December 09, 2010, 01:49:59 PM
If you sit in the middle, toeing the speakers inward will beam the treble directly toward your ears.
