Mourquiet upgrade: impressions?
denti alligator · 8744
Offline denti alligator
on: June 22, 2021, 06:42:42 AM
A search for those who’ve upgraded the attenuator to the MourQuiet in their Stereomour II yielded very little. Could those of you who have installed this upgrade comment on the differences? Thanks!
- Sam
Offline Jamier
Reply #1 on: June 23, 2021, 07:16:50 PM
Sam, I installed the Mourquiet, about three years ago. My take on the upgrade is that it absolutely improved midrange clarity, but it came at the cost of some insertion loss. If you have a preamp in front of your SII this is probably not an issue, but if you like to run your source right into the SII you may not appreciate the loss in gain.
Jamie
James Robbins
Reply #2 on: June 24, 2021, 08:06:33 AM
I'm also using the MQ upgrade in my SII (plus 2 shameless copies in my S.E.X. amps). It works perfectly and the steps are small enough to get the volume where it belongs.
While I concur with most of the positive aspects of the upgrade (I can't speak to the low level imbalance of the original pot with my 94dB speakers) there are times I miss the original balance control. Likely listening area issues, certain recordings highlight a shift in the image that can no longer be simply adjusted out. Just my $0.02.
Reply #3 on: June 24, 2021, 08:31:51 AM
Hm. Two downsides. Not what I expected.
- Sam
Reply #4 on: June 25, 2021, 02:36:19 AM
Sam, I don't believe either of us were trying sound negative - heck, I like it enough that I had chassis plates made and chased down parts so I could duplicate it in my other amps. As Jamie said, it does what it is purported to do sound-wise. Only you know your system and what you are looking for.
Reply #5 on: June 25, 2021, 03:05:52 AM
No, I hear you, but the balance is a feature I use, and I don’t have a preamp (except for an old Quickie), so a little loss in gain is something to consider.
- Sam
Offline Jamier
Reply #6 on: June 27, 2021, 01:43:10 PM
I don’t want this discussion to leave those w/o the MQ believing that it is not a worthwhile addition to their SIIs. It’s a bit like the DC filament upgrade, not everybody needs it, but if you have speakers over, say, 92db sensitive, then you probably do. The MQ is a real step up if you have a smallish listening area and listen near-field or semi near-field. You don’t need the gain in that situation but you will really appreciate the improved midrange (and bottom end).
I have MQ installed in an SII that I use in a relatively small area (12x14). The SII drives the MT section of a semi-active 3 way. The xover point with the Woofer section is about 200Hz / 12 dB/oct. In this application the MQ is really a plus. With the SII working above 200Hz there isn’t a need for lots of gain but the improved sonic performance is nice.
Jamie
« Last Edit: June 27, 2021, 01:45:04 PM by Jamier »
James Robbins
Reply #7 on: June 27, 2021, 03:24:34 PM
The MorQuiet and the stock attenuators have roughly the same insertion loss, so there shouldn't be much of a difference in gain (maybe 1dB).
Reply #8 on: July 02, 2021, 04:51:07 PM
The gain is less of a concern for me than the balance. I’m assuming the balance is pretty, um, balanced with the upgrade and that adjustment isn’t normally necessary?
- Sam
Offline Natural Sound
Reply #9 on: July 02, 2021, 05:52:53 PM
The use of precision resistors in MQ puts the balance precisely in the middle. I myself never used the balance control when my Stereomour II was stock. I appreciate the even steps of the MQ especially at low volume where a two gang potentiometer can be "lopsided" at times. Aside from that I heard an improvement in sound quality as well with the MQ.
Reply #10 on: July 02, 2021, 06:45:32 PM
Natural Sound makes a good point - the biggest reason for a balance control is to allow correction for an ordinary volume control at the lower settings. That's one reason it is usually not needed with a stepped control. There are other reasons, but they are much less  frequently needed.
(1) sometimes the exigencies of architecture and communal living require speaker placement that is unsymmetric enough to need compensation;
(2) occasionally, you may have tubes with unmatched gain - usually not significant, but not always;
(3) sometimes you might want to listen to each speaker separately, to identify problems;
(4) you may have unbalanced hearing loss;
(5) the recording itself (or a phono cartridge) could be unbalanced
All but (2) are unrelated to the amp itself, and most people, most of the time, don't need or use the balance control. When PB developed the MourQuiet/BeeQuiet coarse/find level control, I started adding them to preamp designs as an inexpensive way to do something functional with the second hole in the chassis.  Off topic but possibly interesting, that's the same way the shunt-regulated driver in power amps came about - looking for something useful to do with the second triode in a dual triode driver.  :^)
Online Thermioniclife
Reply #11 on: July 02, 2021, 07:31:41 PM
PJ. In my opinion answers 1 and 4 apply to me in my living room although in my evil laboratory I listen in near field and can move the speakers as needed. I also listen to headphones and really enjoy the C2A with the balance control. We are all different and weird in our way.
Reply #12 on: July 10, 2021, 03:54:55 AM
I think my main concern is the balance, which I definitely use, meaning the knob is nowhere near the center to get a properly balanced sound.
- Sam
Reply #13 on: July 10, 2021, 10:28:56 AM
But are you using the balance control because the channel balance of the stock pot isn't that great?  Or for some other reason?
Reply #14 on: July 10, 2021, 10:39:22 AM
Not sure why the balance is appears to be off. I remember asking in another thread if the reason I need to use it so much is a sign of something else being wrong and was told no.
- Sam
