Mains hum+ FFT graph included
Shamsyrup · 2556
Offline Shamsyrup
on: June 23, 2021, 09:57:53 AM
Hi, previously my stock crack had a slight audible hum. I tried resoldering every joint with new solder and cleaned all the pins. Used bigger caps but the issues remained. Surprisingly when I changed the power supply diodes to a single package vishay bridge rectifier the audible hum was gone, well at least with hd600s. But when I use the 600ohm beyerdynamic dt990 I can again hear the slight hum although not as noticeable as before. Same with high impedance iems. The hum does not change with the volume knob.  The magnitude remains same no matter how much I turn the volume knob or change the dac volume. My mains frequency is 50hz.
Is there any solution ? Or this is just normal for crack ? Any suggestions are highly appreciated.
Thank you.
Reply #1 on: June 23, 2021, 04:08:09 PM
Can you post some build photos?  Are the mains power outlets where you are earthed?
Offline diynewbie
Reply #2 on: June 24, 2021, 01:17:18 AM
I would have thought that a 1 khz hum would have been coming from outside of the crack - either something on mains, in the source chain or through the air.  Is it common for circuitry like the Crack to generate such frequencies?
Offline Shamsyrup
Reply #3 on: June 24, 2021, 01:30:40 AM
Yes I will post pictures as soon a reach home.
Offline Shamsyrup
Reply #4 on: June 24, 2021, 01:32:04 AM
1khz is the signal I am injecting. Actual hum is 50hz and it's 2nd order harmonic of 100hz.
Reply #5 on: June 24, 2021, 04:54:16 AM
What is the voltage of that 1kHz input? Is the gain setting at maximum?
« Last Edit: June 24, 2021, 04:56:00 AM by Paul Joppa »
Offline Shamsyrup
Reply #6 on: June 24, 2021, 08:14:22 AM
Line voltage is about 1.8volt p2p. Which gain ? The gain of crack or the interface ?
I have added the pictures of mains connection and grounding. Also attached some more measurements and pictures.
Reply #7 on: June 24, 2021, 05:24:31 PM
Can you post a picture of the solder and a picture of any flux that you used?
