Cap upgrades for Eros II
denti alligator · 10153
Offline denti alligator
on: July 10, 2021, 10:25:02 AM
I’m ordering some caps for the Steremour II and thought I’d throw in some for the Eros, too. Which ones will make the most difference, and what uF and voltage ranges would work? Thanks.
- Sam
Reply #1 on: July 10, 2021, 10:27:48 AM
There's just one pair of coupling caps in the Eros.  The size and voltage is listed in the manual.
I would not change out the RIAA caps unless you buy 10 of each and hand match them to ensure you get reasonably close values.
Reply #2 on: July 10, 2021, 10:58:51 AM
Thanks. I’m eyeing the Mundorf ZN series 0.10uF /630V. Anyone have favorites?
- Sam
Offline debk
Reply #3 on: July 10, 2021, 11:02:35 AM
I used V-Cap ODAM Series Audio Capacitors.  I have used them in a few projects and really like them.
Debra K
Eros 2Phono amp
BeePre2, Psvane ACME 300b
Kaiju, Linlai Elite  300b
Rega P6 Ania Pro cartridge
Roon Nucleus
MHDT Labs Orchid DAC
Jager speakers
Reply #4 on: July 10, 2021, 11:06:26 AM
Thanks, Deb. Those are a bit out of my price range, unfortunately.
- Sam
Reply #5 on: July 10, 2021, 11:08:11 AM
That's not the size for the coupling caps.  400V rated caps are more than enough.
Reply #6 on: July 10, 2021, 11:23:12 AM
I’m away from home and don’t have the manual on hand so I went from discussion in these forums. So it’s 0.10uF/400V? Is there a downside to going higher on the voltage or is it just unnecessary?
- Sam
Reply #7 on: July 10, 2021, 11:32:44 AM
No, it's not a 0.1uF cap. Go for at least 1uF.
Reply #8 on: July 10, 2021, 11:43:24 AM
Sorry, I typed wrong. 1uF. The voltage should be 400. Is it ok if it’s higher? 630?
- Sam
Reply #9 on: July 10, 2021, 12:14:00 PM
It's not a problem, but you're potentially paying for a bigger/heavier cap that you don't need. There are some nice Clarity and Multicap 1uF/400V caps available if you want something other than a Solen.
Offline debk
Reply #10 on: July 10, 2021, 05:12:27 PM
Sam,
I have a couple of 1uf Mundorf Supreme Silver/oil caps I'm not using that would work for you.  If you want them PM me your address and I will send them out to you
Debra K
Eros 2Phono amp
Roon Nucleus
Jager speakers
Offline johnsonad
Reply #11 on: July 11, 2021, 03:36:13 AM
Another to consider is one that DocB recommended which is the Solen film and foil.  They have a Tefleon film and foil and poly film and foil.  The poly is cheap and they sound great.  They are in my Eros2 build.  My Eros1 build has the Teflon version.  They don't need to be 1uF.  I believe Parts Connexion has 0.82uF Teflons.
Both take a little time to break in.  Tube rolling will have a greater impact in the Eros (IMO) and the caps will allow you to hear the changes a little clearer. Just my 2 cents.
Offline Jameson
  • Intern in Chief
Reply #12 on: July 11, 2021, 04:21:41 AM
Deb,
If Sam doesn’t want them I’d buy them off you.
Jameson O'Guinn
Managing Partner
Offline Tom-s
Reply #13 on: July 11, 2021, 08:07:00 AM
I’m happy with Jupiter wax caps in my Eros.
Went with 2,2uf as that’s what I had.
Going paper oil type you might want to check out Audio Miflex as an alternative.
They get a great score on The humble home made hifi comparison and are affordable compared to many others.
« Last Edit: July 11, 2021, 08:08:36 AM by Tom-s »
Reply #14 on: July 25, 2021, 04:04:43 AM
About to install the 1uF 690V Mundorfs I got from Deb. Just to be sure: these replace the 1.50uF 630V caps that are at the output jacks, right?
- Sam
