Cap upgrades for Eros II
denti alligator · 10008
Reply #15 on: July 25, 2021, 04:17:56 AM
Yes.
Offline denti alligator
Reply #16 on: July 25, 2021, 04:25:19 AM
Thanks. Do I need to protect the leads with heat shrink?  There won’t be but a few millimeters.
- Sam
Reply #17 on: July 25, 2021, 04:26:30 AM
Is there anything else mounted out there that could touch the leads?
Reply #18 on: July 25, 2021, 04:32:44 AM
No.
- Sam
Reply #19 on: July 25, 2021, 04:48:23 AM
Last question: is there any reason I can’t attach the leads to the top (instead of bottom) of the terminal strip?
- Sam
Offline Tom-s
Reply #20 on: July 25, 2021, 05:19:47 AM
You'll be fine Sam. Enjoy the new caps.
In my own Eros i've routed the PCB cable to the bottom . So i'd only need to attach the output cap cable on top mount position.
This helps the ease of changing out capacitors.
Reply #21 on: July 25, 2021, 05:48:12 AM
If you attach the caps to the bottom lugs, there's no twisting force on the lugs themselves.  Attached to the top, heavy caps can try to twist the terminals so the rotate within the phenolic, and that can cause some problems down the road.
Reply #22 on: July 25, 2021, 05:58:16 AM
The leads of these Mundorfs were just too thick too get in the bottom (I had a hard time removing all the solder), so I went with putting them up top.
- Sam
