denti alligator · 10168
Is there anything else mounted out there that could touch the leads?
Last question: is there any reason I can’t attach the leads to the top (instead of bottom) of the terminal strip?
If you attach the caps to the bottom lugs, there's no twisting force on the lugs themselves. Attached to the top, heavy caps can try to twist the terminals so the rotate within the phenolic, and that can cause some problems down the road.
