Bottlehead Kits
Crack
Measuring voltages while playing a 60 Hz sine wave. [resolved]
Colonl_Charisma
13320
3
4
5
Colonl_Charisma
Full Member
Re: Measuring voltages while playing a 60 Hz sine wave.
Reply #15 on:
July 23, 2021, 04:14:27 PM
Thanks! This is with the 60 Hz wave playing.
Left channel RCA plug: 1.488 V
Right channel RCA plug: 1.487 V
Ross
Fiio K11 R2R --> Bottlehead Crack --> HD600
Paul Birkeland
Global Moderator
Hero Member
Reply #16 on:
July 23, 2021, 04:20:11 PM
OK, this is helpful information. That's 0.005dB.
What DC resistance do you get from center pin to shell on each RCA jack on your Crack with nothing plugged in?
Colonl_Charisma
Full Member
Reply #17 on:
July 23, 2021, 04:34:36 PM
RCA left = 99.3 k ohms
RCA right = 99.4 k ohms
Nothing was plugged in.
Ross
Paul Birkeland
Global Moderator
Hero Member
Reply #18 on:
July 24, 2021, 05:23:50 AM
Something isn't adding up. To get an imbalance when you plug in your RCA cables, you'd need to load down the DAC, which would show as low impedance across the RCA jacks. Consequently I would question the measured AC voltages.
Colonl_Charisma
Full Member
Reply #19 on:
July 24, 2021, 06:29:45 AM
When I get home, I’ll re-measure everything. I’ll also bend the RCA cables in the angle that they are plugged in at. I have had some issue with this RCA cable in the past with the right channel.
Ross
Colonl_Charisma
Full Member
Reply #20 on:
July 24, 2021, 09:12:24 AM
Quick update! I picked up a new RCA cable, and I took two new readings with a 60 Hz wave playing.
Old RCA cable measurements:
RCA left center pin = 1.487 V
RCA right center pin = 1.368 V
New RCA cable measurements:
RCA left center pin = 1.489 V
RCA right center pin = 1.488 V
Ross
Paul Birkeland
Global Moderator
Hero Member
Reply #21 on:
July 24, 2021, 10:04:27 AM
Time to junk that old cable.
Colonl_Charisma
Full Member
Reply #22 on:
July 24, 2021, 11:17:41 AM
Definitely haha. I'll listen for the rest of the day with the new cable, and I'll see if anything sounds off.
Ross
Colonl_Charisma
Full Member
Reply #23 on:
July 26, 2021, 02:34:51 PM
Hi, PB! I think you can mark this thread as resolved. I've been listening to my Crack for awhile now since switching out RCA cables, and I do not perceive any channel imbalance. What I was experiencing was pretty distinct.
Thanks for your help!
Ross
Colonl_Charisma
Full Member
Re: Measuring voltages while playing a 60 Hz sine wave. [resolved]
Reply #24 on:
August 04, 2021, 06:43:23 AM
I'm back with some new measurements. Turns out my channel imbalance seems to still be present. My headphones sound balanced when just plugging them straight into my computer, but the right channel sounds quieter than my left channel when plugged into my Crack.
I followed the measurement instructions on this thread
https://forum.bottlehead.com/index.php?topic=7788.15
My RCA jack measurements, middle lugs on potentiometer, and A2 and A7 were more or less equal. However, I seem to have a discrepancy when measuring AC voltage on terminals 1 and 5.
AC voltage with amp on and volume pot turned all the way up.
Terminal 1: 6.51
Terminal 5: 6.92
Ross
Paul Birkeland
Global Moderator
Hero Member
Reply #25 on:
August 04, 2021, 06:53:40 AM
That's half a dB, which is audible but not horrible. What is the DCR of each headphone driver?
You may find that tube rolling could yield more equal balance, or you could fit a balance control if you prefer.
Colonl_Charisma
Full Member
Reply #26 on:
August 04, 2021, 06:58:25 AM
I agree. It isn't as bad as what I was experiencing with the bad RCA cable, but I still notice it.
What does DCR mean? I am unfamiliar with the acronym haha.
Ross
Paul Birkeland
Global Moderator
Hero Member
Reply #27 on:
August 04, 2021, 07:00:07 AM
DC resistance. You can use your meter to measure the resistance of each driver, though at 60Hz that measurement may not be so useful.
Colonl_Charisma
Full Member
Reply #28 on:
August 04, 2021, 07:02:47 AM
I can take the measurement now. Do I need to disassemble my HD600 to get to the driver?
Ross
Paul Birkeland
Global Moderator
Hero Member
Reply #29 on:
August 04, 2021, 07:05:04 AM
No, you can measure across the headphone plug. The tip is L+, the ring is R+, and the sleeve is common.
3
4
5
Bottlehead Kits
Crack
