Terminal 22 fails resistance check [resolved]
Universe Man · 1869
Offline Universe Man
on: August 14, 2021, 03:41:12 PM
I am finished with building, and have passed all other tests (including the rest of the resistance tests). For some reason, terminal 22 is just measuring like the terminals marked with *. I checked the bolts and screws on the transformer. Safety ground reads ~0.2. What is the problem here?
Final Update (Solved): I just figured out I had a bad solder at 16L. It works now.
Update: When I measure it in some spots it’s ~1.2, but on the top it still fluctuates. With an alligator clip, it reads 1.1. My meter seems to go to a 0.2 at the 0 terminals, so I’m not sure if I should count this.
Update: So, after a while the resistance reads differently, around 3 or 4, instead of 1.2 with an alligator clip.
« Last Edit: August 15, 2021, 05:36:47 AM by Paul Birkeland »
Reply #1 on: August 14, 2021, 06:14:29 PM
They are still Close to "0"  figure you have the leed resistance plus different clips. I wouldn't sweat it...John
Reply #2 on: August 14, 2021, 06:17:29 PM
All right. I posted another question relating to the voltage test. Any suggestions?
