static in one channel
arugula · 1917
Offline arugula
on: September 26, 2021, 12:44:55 PM
Hi and thanks for any help. I built my Crack and am truly loving it. I have not yet added the upgrade because of a problem: there is static in the right channel only. It does not change when I turn up the volume and is there with no input into the amplifier. When I turn up the volume at highest levels (roughly 3 o'clock) I hear pretty bad hum, but the volumes I use are down around 7-9 O'clock. All the tests in the instructions were fine. Not sure where to troubleshoot first. Thanks much for help.
Reply #1 on: September 26, 2021, 04:48:19 PM
I would start by reflowing every solder joint in the amp other than the power switch and the pins where the LEDs connect.
Offline arugula
Reply #2 on: September 26, 2021, 04:54:23 PM
OK. Thanks.  I way to narrow it down because in one channel? Will give it a shot.
Reply #3 on: September 27, 2021, 06:38:38 AM
Also, clean the tube pins...John
Offline arugula
Reply #4 on: September 28, 2021, 10:12:02 AM
Is it weird to have him when the volume is cranked to very high?
Reply #5 on: September 28, 2021, 10:15:44 AM
That's pretty normal, especially if nothing is plugged into the amp.  If you listened at that level, you'd go deaf in a hurry.
