Help Needed for 0.1μF 100V Soldering on Mainline [resolved]
LouisQ · 5190
Offline LouisQ
Hello,
I am not sure I made the correct soldering.
On page 71&72 of the Mainline manual it says (ref. picture #1 att.) :
-"Bend the leads of a 0.1μF 100V capacitor close to the body of the capacitor. Attach and solder the leads to C4 and C5."
-"Bend the leads of a 0.1μF 100V capacitor close to the body of the capacitor. Attach and solder the leads to A4 and A5."
On both instances I soldered the two leads of the 0.1μF 100V to C4 and C5 / A4 and A5 respectively (ref. pictures #2, #3, #4, #5 #6 and #7 att.).
Was soldering all of them together the way to proceed?
Thank you in advance for the help.
Louis
« Last Edit: January 08, 2022, 02:37:19 PM by Paul Birkeland »
Reply #1 on: December 21, 2021, 01:16:00 PM
Looks OK to me. You can power up the amp with the tubes in to be sure they glow if you'd like.
Offline LouisQ
Reply #2 on: December 21, 2021, 01:42:14 PM
Thanks Paul,
I will try the tubes.
Much appreciated :)
Offline LouisQ
Reply #3 on: January 06, 2022, 12:08:09 PM
Hey Paul,
A bit late to the party, but happy new year!
Just to inform you that my Mainline is completed and working properly: it sounds awesome!!
Quick question, there’s no noticeable gain/volume when I switch the impedance switch (HI/low), is that normal?
Thanks so much,
Reply #4 on: January 06, 2022, 12:39:35 PM
There should be a change in volume, but it's not enormous.
Offline LouisQ
Reply #5 on: January 06, 2022, 01:41:02 PM
There is no change in volume.
I tried with different headphones (HD800s, Focal Clear).
Would you have any thoughts?
Reply #6 on: January 06, 2022, 03:35:16 PM
Can your multimeter resolve low AC voltages?  You can play a 60Hz tone into your Mainline and we can check that the output is changing a bit when you flip the switch by using your meter.
Offline LouisQ
Reply #7 on: January 08, 2022, 02:36:41 PM
Hi Paul,
Indeed there's a slight difference, all good thank you.
Have a nice weekend :)
