Resistors to heater
hddeluxe1 · 2936
Offline hddeluxe1
on: December 30, 2021, 01:22:26 PM
    Hey all, just made a stupid mistake and as I was soldering the 3 Ohm- J resistor in  the wire coming out of the resistor broke off. I've been trying to locate another but all it says on it are the
  3ohm-j  no luck online as of yet. any solution would be appreciated. Schematic shows 2 watt I believe. Thanks
Joe "Pug" Stricker
 Moreplay preamp with 6v6-cv509's
 Reduction phono preamp with integration upgrade
 Quicksilver KT-88 monoblocks
 Fluance RT-85 TT with Ortofon 2M Blue
 Teac A2300S RTR
 Klipsch Forte II's
Reply #1 on: December 30, 2021, 01:45:28 PM
The bosses are out of the office and won't be back till Monday.  You can e-mail replacementparts(At)bottlehead(dot)com to request a replacement.
This would be an OK substitute:
https://www.mouser.com/ProductDetail/KOA-Speer/MOSX2CT52R3R0J?qs=sGAEpiMZZMtlubZbdhIBIKK%2F2ze2orzk%252BZlo%252BHNd%2FXc%3D
Offline hddeluxe1
Reply #2 on: December 30, 2021, 02:58:54 PM
   Once again Paul to the rescue. Happy New Year to you and yours!
Joe "Pug" Stricker
 Teac A2300S RTR
 Klipsch Forte II's
Reply #3 on: December 30, 2021, 03:07:26 PM
I'm not going to say it's a good idea, but I'm sure you could substitute a piece of wire for that missing resistor to at least work your way through the build all the way.  If you ran the amp like that long term something would break, but for a few hours of testing and use it shouldn't matter all that much.
