Mainline - Voltage Inconsistencies [resolved]
hpleung · 5214
Offline hpleung
on: January 02, 2022, 05:36:42 PM
Hi,
So all of my voltages check seems about right except for this value:
"Kreg Regulator Board (both sides) 8-12V" ==> My observed value is 3.34 volts on one side and 3.41 volts on the other side.
Any hints on where I should look?
Thanks.
« Last Edit: January 03, 2022, 10:08:02 AM by Paul Birkeland »
Offline hpleung
Reply #1 on: January 02, 2022, 05:41:18 PM
attaching a pic of the board where kreg is measured.
Reply #2 on: January 02, 2022, 06:28:55 PM
If all your other voltages are OK, I would run the amp for a while and see if those voltages start to rise.  3.3-3.4V is still plenty of voltage to operate.
Offline hpleung
Reply #3 on: January 03, 2022, 06:22:24 AM
Hi Paul - Do you mean I should continue with the next step with Biasing or let the unit plugged in and wait until the voltage rise from 3.34 to 8v?
Reply #4 on: January 03, 2022, 06:37:56 AM
Go ahead and move onto biasing.
Offline hpleung
Reply #5 on: January 03, 2022, 06:44:44 AM
Biasing - I can't seem to change the bias. The voltage at terminal 20 remains at 215volts no matter how many times i turn the bias screw clockwise or anti clockwise. I tried both the bias screw at the B side as well as the A side.
Reply #6 on: January 03, 2022, 06:46:16 AM
Did you fold the leads of the little blue pot over as shown in the instructions? What are the OA and OB readings on the center PC board?
Offline hpleung
Reply #7 on: January 03, 2022, 07:10:41 AM
OA is 5.23 and OB is 5.55. And it looks like I did fold the lead (picture attached).
Offline hpleung
Reply #8 on: January 03, 2022, 08:24:32 AM
I re did the solder at the fold just to be safe, and got same result. Which is - I still cannot change the bias which seems to be stuck around 215 volts.
I am getting 215 DC volts on both terminal 20 and 30.
Offline hpleung
Reply #9 on: January 03, 2022, 09:00:28 AM
Hold on - it looks like I miss the connections at D2.
Offline hpleung
Reply #10 on: January 03, 2022, 09:18:04 AM
So fixing D2, resolve the original issue:
"Kreg Regulator Board (both sides) 8-12V" ==> I now get about 9volts instead of the 3.34 volts I got earlier.
However, I am still unable to change the Bias. The voltage measurement at terminal 20 is still 215 volts.
Attached picture of my board.
Offline hpleung
Reply #11 on: January 03, 2022, 09:21:16 AM
Nevermind - I can actually change the Bias. I just had to turn a lot of rotations - I did not realize we had to turn a lot.
Thanks.
