Bottlehead Kits
Legacy Kit Products
Reduction
weird ohms readings
weird ohms readings
hddeluxe1
19483
hddeluxe1
Jr. Member
weird ohms readings
January 28, 2022, 06:01:28 AM
Terminals read as such: 44-10.5 Also noted that the cap is dented in. Cap issue? reflowed terminals with no success.
45- 9.5
47-7.0
Joe
Joe "Pug" Stricker
Moreplay preamp with 6v6-cv509's
Reduction phono preamp with integration upgrade
Quicksilver KT-88 monoblocks
Fluance RT-85 TT with Ortofon 2M Blue
Teac A2300S RTR
Klipsch Forte II's
Thermioniclife
Sr. Member
Re: weird ohms readings
Reply #1 on:
January 28, 2022, 06:33:57 AM
Yikes, was that cap dented when you installed it? I would replace it before doing anything else. also check the diodes on that terminal strip for proper orientation.
hddeluxe1
Jr. Member
Reply #2 on:
January 28, 2022, 06:40:02 AM
checked the diodes and all properly installed. The cap is what worries me so I'm going to replace it.
Joe "Pug" Stricker
Teac A2300S RTR
Klipsch Forte II's
Paul Birkeland
Global Moderator
Hero Member
Reply #3 on:
January 28, 2022, 06:41:20 AM
What are the units on those numbers you're reading? I wouldn't necessarily replace the cap right away, but if you're seeing something like 10.5M, that's not a problem.
hddeluxe1
Jr. Member
Reply #4 on:
January 28, 2022, 07:30:15 AM
plugged it in . but getting 80 volts dc to terminal 45 and 78 to terminal 46 with tubes in. Safety check in manual shows 0vdc.The led's are lit and the tubes are lit.
This is just the reduction without the integration upgrade.
Joe "Pug" Stricker
Teac A2300S RTR
Klipsch Forte II's
Paul Birkeland
Global Moderator
Hero Member
Reply #5 on:
January 28, 2022, 08:09:35 AM
Can you let me know what the units are on those resistance numbers you're getting? I would clarify that before attempting to power up the unit.
Bottlehead Kits
Legacy Kit Products
Reduction
weird ohms readings
