X2 outputs?
RestoredSparda · 4513
Offline RestoredSparda
on: February 10, 2022, 03:06:04 PM
Hi!  I'm about halfway through a stock Beepre2 build. I plan on building this as designed first to ensure its working properly.
I am however in need of a second output, as I will be using this before a Mainline for headphone use, and before a poweramp for speakers.
Would it be simple as adding a second pair of jacks for output, and paralleling the first output to those? Is there a preferred way to add a second output to this pre? Both need to be single ended (not balanced) in my case.
Reply #1 on: February 10, 2022, 03:20:58 PM
Yes, you can fill the extra set of holes with another pair of jacks.  The second set of outputs that come with the second upgrade will include XLR jacks, but you can just leave those off if you opt to install the rest of the second upgrade.
Reply #2 on: February 10, 2022, 03:37:52 PM
Perfect.  Thanks Paul!
Reply #3 on: February 11, 2022, 10:45:15 AM
Finished her up and slapped on some stain.
After some rearranging I am really enjoying this pre. It's a bit overkill for my current setup, but I've never heard my wharfendales sing like this before. Vocals are Unreal.
Reply #4 on: February 11, 2022, 11:38:31 AM
There's nothing wrong with overkill!
Reply #5 on: February 11, 2022, 12:17:25 PM
That's the spirit! Haha
Reply #6 on: February 16, 2022, 10:30:10 AM
Hey Paul!
I went ahead and installed the new jacks. Before I fire her up, does this look correct to you?
Reply #7 on: February 16, 2022, 10:31:48 AM
Looks good!
Reply #8 on: February 16, 2022, 10:33:41 AM
Thank you sir!
