Hum Pot adjustments [resolved]
ArtnShit · 67473
Offline ArtnShit
Reply #75 on: February 27, 2022, 02:44:42 PM
1.496Vac LO
.491Vac RO
Using the ground for each respective RCA jacket.
a&s
Reply #76 on: February 27, 2022, 02:46:38 PM
OK, how about the AC voltage for the upper and lower lugs on the volume pot that are closest to the rear of the chassis?
Offline ArtnShit
Reply #77 on: February 27, 2022, 02:56:29 PM
Upper 1.502 V ac
lower .381 V ac
a&s
Reply #78 on: February 28, 2022, 04:28:28 AM
Can I see some photos of the build on the weak channel? The numbers you're posting indicate a weak channel, but not completely dead.
Offline ArtnShit
Reply #79 on: February 28, 2022, 06:44:59 AM
I think this is the right channel, right?
a&s
Reply #80 on: February 28, 2022, 06:55:22 AM
You need to add more solder and a lot more heat to the joints in this kit.  The sound likely isn't making it out from solder joint issues.
Offline ArtnShit
Reply #81 on: February 28, 2022, 07:01:50 AM
Makes sense, this was the first one I built. Should I just go over all of em adding more?
a&s
Reply #82 on: February 28, 2022, 07:06:21 AM
Yes, don't forget to add more heat too so the solder flows out properly.
Offline ArtnShit
Reply #83 on: February 28, 2022, 09:00:07 AM
I have gone over every joint on the right side around the 300b socket and I am still not getting a full signal. Any suggestions for areas to pay more attention to?
a&s
Reply #84 on: February 28, 2022, 11:57:46 AM
You can do another 60Hz AC signal measurement and look for the AC voltage on the rear lead of each 10uF cap (not the forward lead that wires to each 4 pin socket).
Offline ArtnShit
Reply #85 on: February 28, 2022, 12:53:02 PM
L 1.481v ac
R .332v ac
Attaching the pics of resoldered joints. Thanks!
a&s
Reply #86 on: February 28, 2022, 01:06:23 PM
I suspect that the blue capacitor on the weaker channel is loose on one end (or both).
Offline ArtnShit
Reply #87 on: March 01, 2022, 05:23:12 AM
I have re-soldered all of the joints and I am pretty sure nothing is loose at this point. Still getting a much weaker signal from that channel, its pretty hard to pick up any AC signal from the outbound lead of the 10uf Cap. I am attaching resoldered pics just in case I am missing anything else. Other than that are there any other troubleshooting measures I should be doing?
a&s
Reply #88 on: March 01, 2022, 05:26:55 AM
You have the output shorted with this wiring error.
Offline ArtnShit
Reply #89 on: March 01, 2022, 05:48:42 AM
:O wow, its fully playing thru both speakers now. Thank you so much for walking me through this really long troubleshooting situation. It's silly it was a miswiring, but I am extremely grateful for your help and responsiveness.
One last question I have about the BeePre now that it is in the system - There is a small buzz that happens when I turn the volume past 75% or so. The Kaiju plugged in by itself was nearly silent. Is this the gain of the BeePre? I have the Bee2Quiet attenuator upgrade on the way now, would that remove some of that?
Thank you again, so much!
a&s
