Hum Pot adjustments [resolved]
ArtnShit · 67671
Reply #90 on: March 01, 2022, 05:50:06 AM
Replacing the 130 ohm 2W resistors with 27 ohm 2W resistors can take that out, as will the second upgrade that we are releasing shortly.  The noise shouldn't be intrusive under normal listening conditions.
Offline ArtnShit
Reply #91 on: March 01, 2022, 06:07:27 AM
Yeah, it pretty much disappears once the music is actually playing. If I were to swap out the resistors would that impinge on the new upgrade down the pipeline at all? Is there a specific resistor/brand you'd recommend?
a&s
Offline ArtnShit
Reply #92 on: March 01, 2022, 06:09:13 AM
Just found your post on it! putting in that order! Thanks PB!
a&s
Offline ArtnShit
Reply #93 on: March 01, 2022, 06:11:55 AM
What's the time frame of the second update?
a&s
Reply #94 on: March 01, 2022, 06:45:10 AM
I just received the missing pieces I need to build my BeePre out according to the manual instructions.  I'm at the tail end of a flood of repairs (8 arrived in the span of 3 days!) and custom builds, then I can move onto this.  One of those repairs remains, as do two Stats that need to get built first.
