Voltage check problem [resolved]
BillB · 4403
Offline BillB
on: March 10, 2022, 08:55:47 AM
Hello, I ran the voltage checks on my StereomourII build, and all the numbers came out very close except for #7. My meter reads 0. It should read 170_230 VDC. I ran through the entire build step by step again and found no bad solder joints, touching wires, or mistakes. Any suggestions? Thanks much.
« Last Edit: March 10, 2022, 02:53:10 PM by Paul Birkeland »
Reply #1 on: March 10, 2022, 09:04:02 AM
This may be fairly easy to debug with a couple of build photos.
What DC voltage do you get at IA on the C4S board?
Offline BillB
Reply #2 on: March 10, 2022, 09:10:27 AM
Paul, I get 410.
Reply #3 on: March 10, 2022, 09:11:49 AM
Some build photos will probably help here.
Offline BillB
Reply #4 on: March 10, 2022, 09:27:34 AM
Here's the photo Paul
Reply #5 on: March 10, 2022, 10:06:47 AM
If you pull the 12AT7 out of that side, does the voltage pop up?
Offline BillB
Reply #6 on: March 10, 2022, 10:30:04 AM
No change after pulling 12at7, still 0. I earlier switched the 12at7 tubes, still 0.
Reply #7 on: March 10, 2022, 11:24:37 AM
This is very likely to be a solder joint issue on the C4S board.  I would reflow all of the joints other than the ones for the LEDs (they don't take much heat to solder properly).
Offline BillB
Reply #8 on: March 10, 2022, 02:01:14 PM
 Paul, good call! All the voltage numbers check out. Thanks for your expertise.
