Bottlehead Kits
Stereomour II
Startup Sound?
Startup Sound?
Herbertk
3588
Herbertk
Jr. Member
Startup Sound?
March 16, 2022, 08:11:48 AM
So I have been playing around with different tubes
Might be forming a slight obsession evidence attached haha... (tubes for SMII and Moreplay)
anyhow my question is this when I used a different set of tubes there was a different sound when you switch the amp on a slight crackle I have not checked which tube exactly but I wondered if this is normal and even more interested to find out what it is I am hearing ?
Paul Birkeland
Global Moderator
Hero Member
Re: Startup Sound?
Reply #1 on:
March 16, 2022, 08:29:29 AM
Some noise during warmup is completely normal. If the noise persists, then it may help to do a bit of debugging to find the source.
Herbertk
Jr. Member
Re: Startup Sound?
Reply #2 on:
March 16, 2022, 08:39:59 AM
Thanks ill try and isolate it and see if it is a specific tube / tubes doing it...
It is only during warmup after it sounds great.
Last Edit: March 16, 2022, 08:44:13 AM by Herbertk
ccmccull
Full Member
Re: Startup Sound?
Reply #3 on:
March 16, 2022, 09:05:12 AM
Not a steromour, but I was also surprised to hear this startup noise on my s.e.x. amp when listening through headphones. It's like a glassy tinkly crackly sound that lasts for just a few seconds. It's rather pleasurable actually!
Colin. Insta @act4audio
2wo
Hero Member
Test
Re: Startup Sound?
Reply #4 on:
March 16, 2022, 05:42:59 PM
Figure you take a precision device, from room temperature to too hot to handle and hit it with high voltage,I little snap, cracke and pop should come as no surprise...John
Bottlehead Kits
Stereomour II
Startup Sound?
