First startup ... Pls Help!
mlineHK · 21835
Offline mlineHK
Reply #15 on: March 25, 2022, 10:47:01 PM
Here are the readings.
Reply #16 on: March 26, 2022, 04:31:41 AM
Can you just type them up into a nice list? It looks like you have at least one Breg that's 300V.
Offline mlineHK
Reply #17 on: March 26, 2022, 04:32:33 AM
Working fine tho. Tks.
Reply #18 on: March 26, 2022, 04:40:10 AM
It's not a good idea to use an amp that doesn't pass its voltage checks.  This can damage your amplifier and/or headphones.
Offline mlineHK
Reply #19 on: March 26, 2022, 04:49:03 AM
IA Side A [275v] 304v
IA Side B [275v] 306v
+275v DC [275v] 306v
+6.3vDC [55-65v] 59v
-6.3vDC [55-65v] 53v
BregA [220v] 304v/ Breg B [220v] 303v
-reg A [0v] 0v / reg B [0v] 0v
Kreg A [8-12v] 1.32v / Kreg B [8-12v] 1.29v
Offline mlineHK
Reply #20 on: March 26, 2022, 04:50:36 AM
thanks paul for having patience with me.  here u go and hope we can find out and correct the problems.
Reply #21 on: March 26, 2022, 05:02:42 AM
Neither of your high voltage regulators are working appropriately. Are you able to set the bias voltage for each 6C45P as directed in the manual?
Offline mlineHK
Reply #22 on: March 26, 2022, 05:41:13 AM
yes i was able to set both the bias to 145v.
Reply #23 on: March 26, 2022, 05:44:32 AM
What are OA and OB on the center PC board?
The 1V at Kreg and 300V at Breg means the 12AU7 in the middle is sucking down nearly limitless current.  The simplest way for this to happen would be a wiring error on the high current C4S boards.
Offline mlineHK
Reply #24 on: March 26, 2022, 06:19:59 AM
i am not sure what u mean by the OA & OB on the center pc board.   the OA connection of the center pc board is a white wire connected to C1.  the OB is connected to A6 if thats what u mean .
Offline mlineHK
Reply #25 on: March 26, 2022, 06:29:13 AM
OA 1.6V / OB 1.9v on the center pc board.
Reply #26 on: March 26, 2022, 06:40:07 AM
Can you unscrew each of the big C4S boards and post a photo of the bottoms of those boards?
Offline mlineHK
Reply #27 on: March 26, 2022, 06:45:16 AM
Here.
Reply #28 on: March 26, 2022, 07:23:50 AM
I would add some solder and a lot more heat to all the solder joints on those boards except the ones where LEDs connect.
Offline mlineHK
Reply #29 on: March 26, 2022, 05:43:32 PM
ok thanks let me try that first and retest the V.
