Bottlehead Kits
Stereomour II
Stereomour for headphones
thoven0215
3798
thoven0215
Full Member
April 01, 2022, 03:04:04 PM
A quick question. For 300 ohm 100 db sensitivity, what should I be setting the output impedance to? Thank you.
Sihwan
Paul Birkeland
Global Moderator
Hero Member
Re: Stereomour for headphones
Reply #1 on:
April 01, 2022, 05:17:45 PM
100dB at what power level?
thoven0215
Full Member
Reply #2 on:
April 02, 2022, 03:16:45 AM
100 decibels per milliwatt
Sihwan
Paul Birkeland
Global Moderator
Hero Member
Reply #3 on:
April 02, 2022, 05:57:10 AM
I would start at 2 ohms. 100dB/1mW is quite sensitive! On the 2 ohm tap, I think you'd have around 80mW into 100 ohms, so way more than enough power to say the least.
thoven0215
Full Member
Reply #4 on:
April 04, 2022, 04:27:03 AM
For connecting a headphone jack, would I just solder the grounds from both right and left and connect it to the ground on the headphone jack, and the right and left to their corresponding places?
Sihwan
Paul Birkeland
Global Moderator
Hero Member
Reply #5 on:
April 04, 2022, 04:43:49 AM
Yes, or you could use an adapter cable.
Bottlehead Kits
Stereomour II
