Stereomour for headphones
thoven0215 · 3799
Offline thoven0215
on: April 01, 2022, 03:04:04 PM
A quick question. For 300 ohm 100 db sensitivity, what should I be setting the output impedance to? Thank you.
Sihwan
Reply #1 on: April 01, 2022, 05:17:45 PM
100dB at what power level?
Offline thoven0215
Reply #2 on: April 02, 2022, 03:16:45 AM
100 decibels per milliwatt
Sihwan
Reply #3 on: April 02, 2022, 05:57:10 AM
I would start at 2 ohms.  100dB/1mW is quite sensitive! On the 2 ohm tap, I think you'd have around 80mW into 100 ohms, so way more than enough power to say the least.
Offline thoven0215
Reply #4 on: April 04, 2022, 04:27:03 AM
For connecting a headphone jack, would I just solder the grounds from both right and left and connect it to the ground on the headphone jack, and the right and left to their corresponding places?
Sihwan
Reply #5 on: April 04, 2022, 04:43:49 AM
Yes, or you could use an adapter cable.
