Voltage Test [resolved]
hpleung · 4518
Offline hpleung
on: April 09, 2022, 11:09:02 AM
Hi,
I am just starting with my Kaiju (Limited Edition, Walnut). I did a voltage test at the beginning and tested:
1/ 119.3 volts when plugged in and Switch is On.
2/ 1.7 volts when plugged in and Switch is Off
3/ 0.02 volts when plugged off and Switch off.
The measuring device is a Fluke.
Is this normal? Shouldn't I get 0 volts in both 2 and 3 above?
Thanks.
« Last Edit: April 09, 2022, 01:37:29 PM by Paul Birkeland »
Reply #1 on: April 09, 2022, 01:06:23 PM
Your DVM has a very high input impedance and is happy to measure induced 60Hz noise, so what you're seeing isn't abnormal.
Offline hpleung
Reply #2 on: April 09, 2022, 01:34:53 PM
Thank you
