Blown 300B, help requested [resolved]
Bobinsms112 · 18211
Offline Bobinsms112
on: June 04, 2022, 03:43:45 AM
Hi there,
For the past 3 years I have had a nicely operating Kaiju with DC filaments.  The other evening the left channel 300B went neon and croaked.  Put some new 300B tubes in and the left channel is more or less out with just some faint sound coming from it.  Swapped tubes and the issue doesn't follow the channel so I think it is definitely an issue on the left channel due to the tube blowing.  There are no obvious issues looking at the underside of the chassis on the left side.  Any idea where to start troubleshooting this with my volt-meter so I can get the Kaiju back in action?
Thank you in advance,
Matt
« Last Edit: July 17, 2022, 07:27:16 PM by Paul Birkeland »
Reply #1 on: June 04, 2022, 05:11:23 AM
Measure the DC voltages on the 4 pin socket on that side.  Also measure IA, OB, KregA, and KregB on the driver board on that side.
Offline Bobinsms112
Reply #2 on: June 05, 2022, 07:31:46 AM
Hi there, thank you for the reply.  Left side measurements as follows:
C1 74.2
C2 426
C3 0
C4 69.2
IA 455
OB 211
KregA 3.5
KregB 7.6
Thank you,
Matt
Reply #3 on: June 05, 2022, 07:39:01 AM
Everything is working properly on that end.  If you have garbled sound, I would look at the speaker wire connections between the binding posts and the OT and the jumper(s) on the OT itself.
Offline Bobinsms112
Reply #4 on: June 05, 2022, 11:27:06 AM
Thank you Paul.  I checked and re-heated the OT tabs and the binding post tabs. After hooking it to the speakers it was maybe not as bad as before but still a very noticeable imbalance.
After getting it on the bench again, I noticed that 46 U and 32 U were out of wack so I also adjusted the trim pots so 46U and 32 U both = 175.  I also reheated IA/OA and IB/OB.  Fired it up again and it still sounds out of balance, like there is info missing from the left channel with vocals more prevalent on the right side.    Measurements for the left and right channels still seem close except for the following:
Kreg A (Left): 2.55
Kreg A (Right): 3.5
OA (Left): 206
OA (Right): 299
IB (Left): 206
IB (Right): 298
Nothing else stands out to me at the moment.
Thank you again for your assistance in troubleshooting this.
Matt
Reply #5 on: June 05, 2022, 01:02:30 PM
The OA is definitely indicative of what you're hearing.  Oddly enough nothing as of yet really has anything to do with the 300B.
I would recommend swapping 5670s between channels just to see if the problematic voltage follows a tube.
If the problematic voltage stays put, it would help to know what OA is on the offending side with no 5670 in that socket after the amp has been on for at least 20 seconds.
Offline Bobinsms112
Reply #6 on: June 05, 2022, 03:09:31 PM
Hi there,
I tried another pair of Raytheon 5670s while hooked up to speakers and got the same audible issues with the 5670.  I put the stock GE's back in on the bench and the voltage stayed put when i switched them around.  I then did as you said and removed the left channel 5670 and waited a minute.  The OA reading on the side with the 5670 removed was 358.  Will await next steps.
Thank you again Paul, I appreciate your time.
Matt
Reply #7 on: June 05, 2022, 03:44:51 PM
I would replace the 431 regulator on the B side of that C4S board.
Offline Bobinsms112
Reply #8 on: June 05, 2022, 03:55:19 PM
Thank you again Paul, I will send a message to the queen shortly seeing if that can be sent.
Best,
Matt
Offline Bobinsms112
Reply #9 on: June 14, 2022, 01:04:22 PM
Hi Paul,
Received the new regulator and swapped it in.  Voltage readings really haven't changed from my 6/5 11:27 post.   Not sure where to go next.
Thank you,
Matt
Reply #10 on: June 14, 2022, 01:14:36 PM
Are you able to adjust your OB voltage at all?  The KregA being about 3.5V and OB being over 200 is a bit odd.  If you are unable to alter the voltage at OB by turning the blue trim pot, that would be an additional symptom to list and would help explain what's going on with the high voltage regulator.
Offline Bobinsms112
Reply #11 on: June 14, 2022, 03:18:50 PM
On the left side (where the regulator was replaced) OB is 175 and is adjustable.  Same with the right side of the chassis. I just re-measured everything again, values below.
left
C1 72
C2 421
C3 0
C4 67
IA 450
IB 204
OA 204
OB 175
KregA 2.54
KregB 6.89
right
B1 70
B2 422
B3 0
B4 75
IA 452
IB 297
OA 297
OB 174
KregA 3.5
KregB 6.63
Reply #12 on: June 15, 2022, 04:47:49 AM
Can you post some photos of the 9 pin socket on the side giving you problems?
Offline Bobinsms112
Reply #13 on: June 15, 2022, 11:56:15 AM
Hi Paul, see attached.
Thank you,
Matt
Reply #14 on: June 15, 2022, 12:44:22 PM
What's the voltage at the X pad on the B side?
From what I can tell, the B C4S that loads the 5670 works, the 431 bias circuit where the blue trim pot is works as well, you have a new 431 regulator on the other side of the C4S board (the B side, hopefully you didn't put the replacement in the A side), and with no 5670 the OA/IB voltage pops up to 360 which is what we would want.
The kinds of problems that this would leave would be solder joint and/or resistor problems in the regulator portion of the B side of the board, some kind of issue with the wiring on the 9 pin socket (if the grid stopper that goes from the 9 pin socket to the middle lug of the 5 lug strip behind the socket with all the zener diodes breaks off, you'd get some wonky annoyances like this), or possibly a broken wire going to Kreg on that B side of the board, or even a broken wire jumper on the PC board.
