Mysterious interaction between EF tube placement and channel balance
ccmccull · 2802
Offline ccmccull
Hi folks,
I have a fun conundrum for you. First off, I have the amp running beautifully so there's nothing to solve exactly, but I did notice this weird behavior and wanted to see if anyone could explain it.
All resistance and voltage checks were well within spec. I can provide them if they're useful. And photos too if you want.
When I first hooked up the eros, I had a distinct feeling that the phantom center channel was pushed ~30% toward the left speaker. So I started taking measurements as suggested in https://forum.bottlehead.com/index.php?topic=13072.0.
I recorded them in the following google sheet: https://docs.google.com/spreadsheets/d/1WUQ_Z-eWfubSRfNxxPuCLwYB4QuHu0oBYpv9H1EhPws/edit#gid=0
Indeed, Left / Right was consistently ~1.25 , between 20 to 10,000 hz. So it didn't seem like an eq issue. Next I swapped the EF86's. The L/R reduced to ~1.05! I assume that's within tolerance, and it audibly places the phantom center right in the middle of the soundstage.
Then I cleaned the EF86 pins and re-tested, and swapped them back and forth for more measurements. Same results!
So I have a "good" pairing EF86s to the two sockets, and a "bad" pairing. What could cause this?
Colin. Insta @act4audio
The two triodes in the 6922 have slightly different gains, and so do the two EF86 pentodes.
Offline ccmccull
Thanks Paul.
This comment helped me realize I can use the data to estimate the gains in the 6922 and the EF86 separately. Or at least I can estimate their individual relative gains (Left / Right), since I don't have an accurate input voltage measurement (it's lower than the minimum 10mV reading on my DMM). And the EF86 swapping allows me to generate two replicate estimates at each frequency.
I added my math and estimates to the sheet if anyone's interested.
Summary:
Tube       Left Gain / Right Gain
6922              ~1.15
EF86              ~1.09
So by swapping the EF86 tubes I can almost cancel out these two gain imbalances. (1.15 / 1.09 = 1.06)
For my education, is this amount of variability in gain typical for EF86's and the two sides of the same 6922 tube?
In my experience, 6922's  tend to be reasonably matched shouldn't be hard to find. The EF86 is a pentode, considereabley more sample to sample variations are normal...John
