Low Voltages [resolved]
Beranga · 2415
Offline Beranga
on: August 06, 2022, 06:20:12 AM
Hello! I just finished building my Crack. Resistance readings were all correct, but the voltages are way low. I'm getting 120V from the wall and wired the Transformer accordingly (getting 6.3 and 178V). Both LEDs light up when started, but turn off after a few seconds. On the Voltage check I'm getting the following:
1. 17V
2. 47V
3. 0V
4. 47V
5. 17V
6. 0V
7. 15V
8. 0V
9. 15
10. 0V
Please help!
« Last Edit: August 08, 2022, 04:54:55 AM by Paul Birkeland »
Cesáreo Ruiz
Offline Beranga
Reply #1 on: August 06, 2022, 09:10:51 AM
Here is a picture of my build:
Cesáreo Ruiz
Offline Beranga
Reply #2 on: August 06, 2022, 03:55:01 PM
Also, I noticed that a 270 Ohm resistor is getting so hot that it's melting the solder on T14 and T15, such as that the standing cap can be moved with no effort.
Cesáreo Ruiz
Offline Mucker
Reply #3 on: August 06, 2022, 04:03:06 PM
It looks like your output caps (both) are installed backwards. Take a look at your manual, the white bands on the caps should be facing outwards.
« Last Edit: August 06, 2022, 04:06:14 PM by Mucker »
Offline Beranga
Reply #4 on: August 06, 2022, 04:41:42 PM
You're absolutely right! I'll go ahead and reinstall them. Thank you!!!
Cesáreo Ruiz
Offline Beranga
Reply #5 on: August 06, 2022, 05:41:33 PM
Switched the output caps orientation and problem solved!!! Voltages are now just right.
Thank you, Mucker!
Cesáreo Ruiz
Offline Mucker
Reply #6 on: August 06, 2022, 06:21:58 PM
Cool! Glad I could help. Enjoy your amp!
