Power Line voltage test [resolved]
mistercheah · 3989
Offline mistercheah
on: October 26, 2022, 04:22:00 PM
I am unable to obtain any values during the powerline test. So to ensure the meter and the power supply outlets are not faulty, I tested the IEC inlet for my Crack. The result was the correct value i.e. 240V.
« Last Edit: October 27, 2022, 04:22:56 AM by Paul Birkeland »
Offline ccmccull
Reply #1 on: October 26, 2022, 06:23:02 PM
One idea: make sure you installed the fuse properly. It doesn't go in the closed square tube. The way to know you have it right if to make sure it'll contact the metal tabs inside the compartment.
Colin. Insta @act4audio
Offline mistercheah
Reply #2 on: October 27, 2022, 01:23:25 AM
Yes, it was the fuse. Problem resolved. Thanks.
