Moreplay 2.2uf upgrade
roycruz23 · 6190
Offline roycruz23
on: November 05, 2022, 09:15:07 AM
Hello! Just finished assembling my Moreplay. Right off the park, this is an awesome preamp. It equals my upgraded (caps and resistors) Hagerman Clarinet. I want to upgrade the 2.2uf caps with a botique caps. I am choosing between 250 volts and 600 volts rating. Your thoughts will be appreciated. Thanks!
Reply #1 on: November 05, 2022, 09:22:25 AM
The startup voltage of that cap is nearly 400v, so unless you know the cap to have a surge voltage rating of 375v or greater, I'd say use a 400v or greater cap.
Offline adeep42
Reply #2 on: November 06, 2022, 10:45:09 AM
Hi Paul, Would this be a cap that would work and what type of improvement would you expect?
Reply #3 on: November 06, 2022, 10:49:48 AM
That will not work; it is ten times less capacitance than the original.
Offline greg788
Reply #4 on: November 06, 2022, 10:58:42 AM
I've done a lot of cap rolling over the years (coupling, speakers, etc.), including my Moreplay
If you don't want to spend a lot, either these:
https://www.partsconnexion.com/CLARITY-81517.html
or these:
https://www.mouser.com/ProductDetail/Cornell-Dubilier-CDE/940C8W2P2K-F?qs=vaqgFBtz3Vu9zwOLQcb%252BiA%3D%3D
These are "OK" and rather hi fi sounding (and the evo silver/gold/oil will be even more so in my experience):
https://www.partsconnexion.com/MUNDORF-70329.html
These I found comparable, kind of lean and hi fi sounding, almost clinical:
https://www.partsconnexion.com/product49152.html
I really disliked Jupiter HT. Waste of money.
These are what I stuck with. They're big and heavy but I don't so much so as to cause a long term problem:
https://www.partsconnexion.com/CLARITY-81531.html
« Last Edit: November 06, 2022, 12:16:21 PM by greg788 »
Offline adeep42
Reply #5 on: November 06, 2022, 11:50:25 AM
Thank you so much!
Offline Mucker
Reply #6 on: November 06, 2022, 01:43:17 PM
Here is one perspective of many different caps:
https://www.humblehomemadehifi.com/Cap.html
Like all of this audiofoolery, one user's boon is another one's bane. As I've often read here, roll your own and tell us how it is  :-*.
« Last Edit: November 08, 2022, 09:07:46 AM by Mucker »
Offline debk
Reply #7 on: November 08, 2022, 06:56:03 AM
I have been very impressed with the V-Cap ODAM caps, and have used them in a number of builds
Debra K
Eros 2Phono amp
BeePre2, Psvane ACME 300b
Kaiju, Linlai Elite  300b
Rega P6 Ania Pro cartridge
Roon Nucleus
MHDT Labs Orchid DAC
Jager speakers
Offline adeep42
Reply #8 on: November 08, 2022, 07:06:44 AM
So many caps. So little time.
Thank you all for the input.
Alan
Offline greg788
Reply #9 on: November 13, 2022, 10:46:14 AM
I forgot about the Odams. Truthfully, just my opinion, but I tried Odams and didn't care for them. I also tried them on the critical series tweeter position of my speakers and didn't care for them there, either. They're OK -- but should be amazing for the $$$ (such are the economics of low-volume manufacturing and diminishing returns in high end audio).
Offline adeep42
Reply #10 on: November 14, 2022, 09:14:19 AM
Well, I bit the bullet and did my first ever cap upgrade. Wound up with Jantzen caps. I'm really happy so far. They've only been in for about 10 hours of playing time so I don't think they're fully broken in. Immediate difference is more detail, but not clinical. The Moreplay has made a huge difference in my second system. It definitely punches way above it's weight class.
Offline roycruz23
Reply #11 on: November 21, 2022, 05:51:03 PM
Can I use Miniature DPDT Toggle Switch 3 Position ON-OFF-ON Rated 6 Amps @ 125VAC to choose between 2 pairs of 2.2uf coupling caps? I’m thinking doing this way will save me time desoldering and soldering.
Reply #12 on: November 21, 2022, 06:36:45 PM
I would not recommend putting coupling caps on a switch.
