EROS Major Hum
olegreg · 6418
0 Members and 8 Guests are viewing this topic.
Offline olegreg
on: November 28, 2022, 09:00:28 AM
I have a major hum coming from both channels on new build.
Also, there is no separation between channels. Source connected to one channel comes out on both sides.
Offline olegreg
Reply #1 on: November 28, 2022, 09:08:35 AM
I wanted to add that the input is shorted to rule out outside sources.
Reply #2 on: November 28, 2022, 10:13:36 AM
How are your DC voltage checks?
Summing channels would tend to indicate a substantial miswire, which should also throw off the DC voltages.
Offline olegreg
Reply #3 on: November 28, 2022, 10:53:45 AM
Rechecked
1A 235 vdc
1B 230
OA 155
OB 156
OC 98
OD 98
OKA 99
OKB 100
OKC 1.63
OKD 1.89
Reply #4 on: November 28, 2022, 10:59:09 AM
Offline olegreg
Reply #5 on: November 28, 2022, 11:42:32 AM
Here you go
Offline olegreg
Reply #6 on: November 28, 2022, 11:57:15 AM
Hum was with SUT wired in per instructions. Rewired without SUTs (pictured) and no hum through headphone.
I must have done something wrong with the SUT wiring.
It was not clear on where to land A1 and B1. I landed on 2 and 15 putting the loading resistor on the secondary of SUT.
Offline olegreg
Reply #7 on: November 28, 2022, 12:46:55 PM
New Hum...
Open or shorted input sounds the same.
Repeating sewing machine sound
I tried to send video with sound, won't accept mp4
Offline debk
Reply #8 on: November 28, 2022, 01:50:27 PM
From the pictures it looks like D2 on the B side of the shunt regulator board is in backwards
Debra K
Eros 2Phono amp
BeePre2, Psvane ACME 300b
Kaiju, Linlai Elite  300b
Rega P6 Ania Pro cartridge
Roon Nucleus
MHDT Labs Orchid DAC
Jager speakers
Reply #9 on: November 28, 2022, 03:33:19 PM
That kind of noise is often wireless interference from a nearby device.
Offline olegreg
Reply #10 on: November 29, 2022, 08:34:40 AM
First: Debra K, Good eye!  Those LED Diodes where probably the hardest component to install on a board. I'm surprised the VDC all checked out, but on close inspection in a darkened room, it was not glowing.  Thank you, Debra
Second: On the sewing machine hum. Paul nailed it... My Sonos sound bar is causing the hum. I will just have to turn it off when I want to listen to music. Thank you, Paul.
BTW, first couple of minutes listening, the EROS sounds great.
I have SUT questions on a different thread.
Offline debk
Reply #11 on: November 29, 2022, 03:27:14 PM
Glad you got it working
Debra K
Eros 2Phono amp
Roon Nucleus
Jager speakers
