High voltages in final test on CS4 board
dehringer · 20757
Offline dehringer
Reply #15 on: January 06, 2023, 03:02:38 PM
With regard to the transistor question, I wasn’t sure if the lead on the 0 ohm resistor going through A3  touching A4, that I mentioned above and led to trying to swap the 2N2222, could have impacted any of the other transistors.
I believe I’ve verified all the resistors on the CS4 board are in the correct place and the components on the board are correctly oriented.
Would any of the resistors off the CS4 board affect the specific voltages I’m having issues with? (I’m learning the importance of resistor orientation for the non-striped resistors when you place it so that you can see the part numbers so you don’t have to remove the resistor from circuit to test it with a multi-meter to know what it is….)
Reply #16 on: January 06, 2023, 03:03:20 PM
You can measure the R1 resistors while they are mounted to the board.
Offline dehringer
Reply #17 on: January 06, 2023, 03:12:10 PM
The R1 and all other resistors on the board are correctly placed.
Reply #18 on: January 07, 2023, 06:15:59 AM
Having repaired a great number of these kits, most of my repair efforts are spent at fixing flaky solder joints and occasionally a backwards part or a miswire.
Offline dehringer
Reply #19 on: January 07, 2023, 09:54:46 AM
I don’t doubt at all that it is likely one of those issues.  I have either reinspected, reheated, removed and resoldered everything on the side of the CS4 board in question at least 10 times.  So I think the board is ok.  Are there any other areas of the circuit I should be focusing in on given the  specific voltage issues?
Reply #20 on: January 07, 2023, 10:04:26 AM
What are the Kreg voltages on the back board?
Offline dehringer
Reply #21 on: January 07, 2023, 10:15:12 AM
The Kreg voltage on the A side is 6.6 and on the B side is 6.3.
Reply #22 on: January 07, 2023, 10:31:06 AM
That tells you that each half of the front board is (very likely at least) attempting to deliver the appropriate amount of current.
I would be very suspicious that the 47K 2W resistor on that side of the front C4S board isn't well soldered in.
Offline dehringer
Reply #23 on: January 07, 2023, 10:55:00 AM
To start from a semi-clean slat, I desoldered, removed, and resoldered the 47k resistor on that side of the CS4 board. I’m still seeing the same voltages.  :-[  ((scratching head))
Reply #24 on: January 07, 2023, 03:34:13 PM
Could I see some pictures of your D socket wiring?
Your 6922 plate and cathode are about at the same voltage, which is really the root of the issue.  This could happen if those pins are somehow shorted together on the 9 pin socket, then the rest of the circuit would respond by trying to correct that issue.
Offline dehringer
Reply #25 on: January 08, 2023, 03:16:00 AM
Sure thing.  I’ve attached pictures of the D socket from a few different angles, trying to get a decent view under the board above it.  Let me know if these are sufficient.
Offline dehringer
Reply #26 on: January 08, 2023, 03:17:59 AM
Additional picture
Reply #27 on: January 08, 2023, 05:47:36 AM
Let's also see the C socket as well.
Offline dehringer
Reply #28 on: January 08, 2023, 12:47:08 PM
Here is the C socket.
Reply #29 on: January 10, 2023, 06:28:53 AM
If you pull out the 6922, then measure the DC resistance between pins 1 and 3 on that socket, what do you get?  How about between pins 6 and 8?
