Solved - Weird infrequent crackling noises from coiled headphone cables
gmony911 · 2219
Offline gmony911
I have been using my crack + HD 650 combo for about a year, but I have always had issues with frequent weird crackling noises. Following several troubleshooting steps, I tried checking for soldering connections, etc. without any improvement.  Abt 6 months ago, I upgraded to the speedball kit, and the issues still persisted with no change.
Turns out I had coiled up my headphone cable for convenience since the stock cable on the 650 is quite long, and my guess is it was acting like an antenna amplifying some signals in the office (computer, phone, etc.). In any case, simply undoing the coiling has removed almost all of the random crackling. I'll still get an occasional one if the cell phone is too close or something, but not nearly annoying as before.
Hope this helps someone who is in a similar situation as I am.
I would still recommend this:
Also triple check where the black wires meet on the headphone jack, as it's pretty common to find one not captured by solder when experiencing issues like these.
Offline gmony911
Thanks, @Paul. Will try both of those.
Offline gmony911
Update
All points were soldered on the jack but re-did the black ones just to make sure. Also applied the two diodes as recommended.
Confirming that I no longer hear any residual noise -- dead silence. Thanks, @Paul!
