MJE5731A voltage different
tintin · 16554
Offline tintin
on: January 02, 2023, 04:00:09 PM
I have just completed an Eros 2 build that did not pass the final voltage checks on the C4S board and the D1/2 D LEDs do not light- going back, the voltages at the MJE5731A on the shunt board are different. Previously at the check point before installing audio circuit, they were both reading 210V, now one MJE5731A (side A) reads 150V while the other reads 210V as before.
IA=IB=270V
OB= Breg side B 210V
OA=Breg side A 150V
Kreg side A = 3.5V
Kreg side B= 7.1V
On the C4S board
IA=220V
IB= 150V
OA= 155V
OB= 145V
OC= 95V
OD= 145V
OkA= 95V
OkB= 145V
OkC= 1.4V
OkD= 0.2V
All tubes are lit fine and I tried another set. I have checked the connections on the PCB board and surrounding 12AU7 socket and everything is ok- am wondering which component or area to check next. Am wondering, given the MJE5731A were correct before installing the audio/RIAA circuit and C4S board, if anything there could affect the readings upstream.
Thank you
« Last Edit: January 02, 2023, 04:36:37 PM by tintin »
Reply #1 on: January 02, 2023, 04:04:34 PM
Solder joints, solder joints, and solder joints.
If you unhook the wire going into IB on the forward C4S board, does OA on the D socket PC board pop back up to around 220V? If so, you should be carefully checking for problematic solder joints on that forward C4S board, as there are likely issues there.
The 0V at OKD with 145V at OD makes me think that the shielded twisted pair wiring feeding pins 4 and 5 on the EF86 socket on that side may not be well connected and allowing that tube to conduct.
Offline tintin
Reply #2 on: January 02, 2023, 04:38:02 PM
Hi Paul thank you for the quick response- yes disconnecting IB makes them return to 220V, so the issue is downstream from the shunt. I will keep looking. Thanks
Offline tintin
Reply #3 on: January 02, 2023, 04:42:14 PM
Have just checked the wiring for pins 4 and 5, they are well connected on both EF86. Is there any other point which is likely to cause this, or should I suspect the circuit board or the pins? Trying to narrow down on where I may need to look. Thanks
Offline tintin
Reply #4 on: January 02, 2023, 06:40:46 PM
I have just reflown all the solder joints and connections of the lower 3 sockets, as well as the C4S board. I checked all connections comparing the incorrect side with the correct one, with a multimeter and nothing is detached or wrongly connected. The problem still persists. I notice that the voltages are equal bilaterally if I disconnect the red wire to OC and OD, if that means anything. Are there any further tests to narrow down the problem?
Offline tintin
Reply #5 on: January 02, 2023, 07:41:08 PM
Images of the board and affected EF86 side
Reply #6 on: January 03, 2023, 04:38:38 AM
Was this build completed with lead free solder?
Reply #7 on: January 03, 2023, 05:58:41 AM
The solder joints on the board generally look good, but in a few spots I see a joint that has either a small gap between the lead and the pad or a solder fillet that doesn't completely surround the lead and cover the pad evenly. Those could be cold joints so it might be worth reflowing them one more time.
Offline tintin
Reply #8 on: January 03, 2023, 12:38:58 PM
Thanks for the ongoing assistance- Paul I have used the same lead solder as in previous projects, definitely not lead-free.
Doc thanks, I have gone back over the board, and added solder, my board now reads
IB= 220V (correct)
OB= 210V (OB=OD=OkB)
OD= 210V
OkB= 210V
OkD= 3V
The left side remains within the correct limits. I connected the right side of the board to the other EF86 and 6922 triode, and the voltages read the exact same as the above points. Since the board is symmetrical, am I correct in concluding that this completely localises the issue to something on the B side of the C4S board then, or could it still be something off the board? Is there anything I can test to further isolate or rule out a faulty component, bad joint or overheated pad? The corresponding MJE350s read the same as above so could it be those?
Thanks again
Edit- I began tracing the voltages and comparing the 2 sides through R1, PN4250 and the MJE350- all legs read 220V until the middle leg of the A side MJE350 becomes 155V, while the middle leg of the MJE350 remains 220V. Does this suggest a faulty MJE350 or could it still be a problem elsewhere? It is a little difficult for me to source parts is why I haven't tried installing another immediately to test.
« Last Edit: January 03, 2023, 01:36:31 PM by tintin »
Reply #9 on: January 03, 2023, 03:11:27 PM
Could you post some photos of the C socket?
Offline tintin
Reply #10 on: January 03, 2023, 07:14:58 PM
Apologies forgot to post these before- I have since fixed up the excess solder on pin 4 and there is no contact with the adjacent pins, but the problem remains the same. I used a multimeter and checked connections from pins to their attachment points and they are also well connected.
Reply #11 on: January 04, 2023, 04:07:06 AM
If you have an adjustable temperature soldering iron, I would turn it all the way up.  A lot of those joints don't look like they have had the chance to flow out properly, which will happen with insufficient heating.
Offline tintin
Reply #12 on: February 05, 2023, 02:35:33 PM
After taking a break from the project, I have returned to it and reflowed all the solder joints with the maximum temperature on my iron. Unfortunately the problem still remains- are there any further resistance or voltage checks I could do to try and narrow down on the issue? Otherwise I may need to send it in to you guys for repair. I have checked the R1 resistors to ensure they are the correct 34.7 ohm ones as well. Thank you
Reply #13 on: February 06, 2023, 04:11:59 AM
Can you post some fresh pics of your resoldered kit?
Offline tintin
Reply #14 on: February 07, 2023, 07:28:45 PM
Here are photos of the EF86 and 6922 sockets, as well as the boards
