MJE5731A voltage different
tintin · 16567
Reply #15 on: February 08, 2023, 04:13:01 AM
I would pop a fresh 2N2222 in on the offending side.
Offline tintin
Reply #16 on: February 12, 2023, 05:27:35 PM
Thanks Paul part is on order- unfortunately I think I may have created another problem while testing; I accidentally shorted the blue wire from terminal 21 to the tab on terminal 28, there was a small spark and now the corresponding MJE5731A reads 170V. Is it possible I have damaged the transistor, or another component? Will wait for your guidance on any further tests and if I should order another part too. Thanks
Reply #17 on: February 12, 2023, 06:02:40 PM
There is no blue wire that goes to terminal 21, do you mean the blue wire on 28 touched something it shouldn't?
I would advise disconnecting the blue wire that leaves that half of the shunt regulator and report the OB and KregB voltages.
Offline tintin
Reply #18 on: February 12, 2023, 06:36:27 PM
Apologies, yes the blue wire from terminal 28 touched terminal 21.
With the blue wire disconnected, OB = 175V, KregB = 0.11V. OA= 220V and KregA=1.9V within range I believe.
Reply #19 on: February 12, 2023, 06:37:18 PM
The 431 regulator on that side appears to be blown.
Offline tintin
Reply #20 on: February 12, 2023, 06:38:56 PM
Thank you for the speedy diagnosis, will order another 431 regulator as well and work from there. Is there reasonable suspicion for any other parts to be ordered in case they may have been affected too? Just trying to save on shipping costs in case.
Offline tintin
Reply #22 on: February 12, 2023, 06:49:13 PM
Offline tintin
Reply #23 on: February 12, 2023, 06:58:47 PM
Got it, will update with results when parts arrive. Thanks again for the ongoing support, much appreciated
Offline tintin
Reply #24 on: February 15, 2023, 08:43:59 PM
I have put in a fresh 2N2222A and still have incorrect readings
With the blue wire disconnected, MJE5731A reads 220V correctly, with it connected, it reads 150V. Further:
IB= 150V
OB= 150V
OD= 145V
OkB= 145V
OkD= 0V
I am sure the 2N2222A was installed correctly, as the legs are 0 resistance to other components connected via the PCB.
Am waiting on the LM431 part which should resolve the shunt board, but that is a problem in the other channel.
Reply #25 on: February 16, 2023, 04:08:06 AM
The 0V at 0KD would still make the 2N2222 suspect.  I believe we have also seen similar issues to yours when a trace on that PC board up front has been damaged.
