Channel Imbalance
Zellouscode · 2361
Offline Zellouscode
on: January 22, 2023, 01:44:06 AM
Crack with speedball
Right channel crackels occasionally and is a few decibels quiter, 12au7 tube needs to be occasionally moved to get good contact, with multiple tubes.
I figure i need to touch up the soldering of those connections. Any idea which ones would be the likely culprits? just all the red connections at that tube socket?
Reply #1 on: January 22, 2023, 05:51:40 AM
Yes, this is a soldering issue.  I would resolder all the joints in the amp other than the LEDs and the power switch.
Offline Zellouscode
Reply #2 on: January 22, 2023, 08:40:51 AM
I got to looking at it and the A2 pin is loose on the 12au7 socket where the white wire comes from the volume pot, I imagine i need to redo the whole socket with a fresh one or would this screwup both channels? Tried resoldering just the RCA input and the 12au7 connections and now only get crackling out of the right channel as well as no sound out the right channel.
Offline Zellouscode
Reply #3 on: January 22, 2023, 08:46:04 AM
moves up and down about an 8th inch
Reply #4 on: January 23, 2023, 05:19:28 AM
No, A2 being problematic would not cause issues in both channels.  It's likely that with a tube plugged in, that socket pin contact won't move around.
