Voltage check failure: Terminal 7 reads 154 VDC, not 170-230 VDC
jmittan · 10603
Offline jmittan
Hi all,
First time poster. I completed my build of the Stereomour II. After doing my voltage check, I identified a failure. Terminal 7 reads 154 VDC, not the correct 170-230 VDC. However, Terminal 14 reads 179 VDC correctly. I did notice the LEDs on the side with the lower reading of the PCB are lit more dimly than the side with the correct reading.
What could be causing the drop in VDC? Does a voltage of 154 to the 12AT7 tube have negative impact (other than an imbalance of sound)?
« Last Edit: March 14, 2023, 08:18:11 AM by jmittan »
The backwards PN2907 is probably responsible for that.
Offline jmittan
Thanks for identifying the incorrect position of PN2907! I was able to detach the transistor and reattach it in the correct position. I am now getting a reading of 203 VDC at terminal 7. However, now I read 0 VDC at terminal 14. This time the LEDs on the other side of the PCB are lit dimly. Why would this be the case?
« Last Edit: March 14, 2023, 10:07:48 AM by jmittan »
Can you post a photo of the build in that area?  0V at terminal 14 would make me suspicious that one wire isn't hooked up to the PC board.
Offline jmittan
Thanks! Here are some photos.
You can pop the wires out of IA, IB, OA, and OB, then rotate the board 180 degrees and reinstall it to see if the voltage problem moves to terminal 7 (which would indicate an issue on the PC board) or stays put at terminal 14 (which would indicate an issue around the socket wiring or terminal strips).
Offline jmittan
I think I found the problem. One of the leads (closest in the photo attached) appears to have broken. Not sure how to resolve this. Do I solder a blob from the top of the PCB to reconnect?
A solder blob could probably be used to fix that.
Offline jmittan
Thank you! much appreciated. I was able to "graft" a cut lead through the through-hole onto the lead of the MJE5731A and solder all together. Terminal 7 reads 203 and terminal 14 reads 184. Though it is now +-15 VDC on the other side, at least it is in the recommended range of 170-230.
cheers!
Those are certainly reasonable values.  If one used plate loading resistors in place of the C4S, you could pin those voltages down a lot tighter, but in this circuit that plate voltage deviation doesn't particularly matter.
Offline jmittan
Thanks. I'm curious. What plate loading resistors would you suggest?
According to another messaging board post “a plate supply resistor should be more than 3 times the plate resistance at your chosen operating point (plate voltage, current, grid voltage), and should drop between half and 2/3 of the supply voltage for best linearity, leaving the other 1/2 to 1/3 of the supply voltage for the tube.” Is this true? Then what would the plate loading resistor values would I use to get the 170-230 VDC? Would I connect the various wires to plate loading resistors? If so, red and black in and white out, instead of the C4S?
Thanks again for your help resolving my issues!
Using a resistor plate load for the 12AT7 driver will increase its distortion substantially - that is, after all, the reason we use current source loads!
That said, the appropriate resistor would be 33K. It should be rated 3 watts or more, and 400 volts or more.
