Stereomour 2 w/ 45’s + hd600’s ?
ludddite · 5673
Offline ludddite
on: March 23, 2023, 12:46:54 PM
I’m slimming down my audio equipment but would like to keep a headphone setup. I have a crack w/ sb that pair well but I like the idea and versatility of using the stereomour if a resistor setup would yield as good or better results.
The stereomour2 has been converted to 45 ,d.c filaments ,shunt reg, sowter opt’s ( 4K 8/16 ohm )
Any real world experience or advice is appreciated.  Thanks.  Mike
Reply #1 on: March 23, 2023, 01:08:44 PM
How is the noise floor with the Sowter transformers in that orientation?  That is certainly the quieter of the possible orientations, but headphone use will depend on what's coming out of the speaker jacks.
As an experiment, you could clip lead the speaker taps to the headphones you want to use as an experiment to double check for proper operation.
Offline ludddite
Reply #2 on: March 23, 2023, 01:30:08 PM
The amp is dead quiet with speakers. Klipsch heresy 1. 95 db@1 watt per m
Offline debk
Reply #3 on: March 23, 2023, 01:35:59 PM
Nice, are these the 5k Sowter parafeed transformers?
I converted my Stereomour2 to 45 tubes and thought about trying the Sowter outputs
Debra
Debra K
Eros 2Phono amp
BeePre2, Psvane ACME 300b
Kaiju, Linlai Elite  300b
Rega P6 Ania Pro cartridge
Roon Nucleus
MHDT Labs Orchid DAC
Jager speakers
Offline ludddite
Reply #4 on: March 23, 2023, 02:37:18 PM
Yes they’re parafeed & they sound great I had them wound for 4K instead of 5 for my original paramours, before I converted the stereomour to 45’s & canalized them. The paramours became 2a3/40’s - 300 b’s w/ tfa 2004’s
