New Moreplay
joegibney · 11252
Offline joegibney
on: May 21, 2023, 04:33:08 AM
Moreplay finished. Now to listen.
Reply #1 on: May 21, 2023, 04:49:04 AM
The washers are a great idea with the hammerite paint.
Offline Natural Sound
Reply #2 on: May 21, 2023, 06:46:50 AM
Great job, Joe.
Offline timindq
Reply #3 on: May 25, 2023, 11:19:59 AM
Looks great. Did you add an extra output?
Source: Lumin D2 with SBooster power supply, 2tb SSD attached to Lumin, Pre: Moreplay, Amp: Bryston 2bSST, Speakers: Joseph Audio RM22XL. Setup in large, well treated dedicated listening space.
Offline joegibney
Reply #4 on: May 25, 2023, 11:37:02 AM
Yes, I needed an extra output for my sub
Just got it hooked into the system. Two JE Labs Simple 45 modified to run 2A3s, big Edcor iron. So far it sounds fantastic 😍.
Offline joegibney
Reply #5 on: May 29, 2023, 09:33:40 AM
Might need to go back to my Foreplay III, Moreplay is broke in, but too harsh.
I have a set of NOS 6v6 on the way. Hope that does the trick.
Offline adeep42
Reply #6 on: May 29, 2023, 11:12:46 AM
Try the NOS metal tube RCA 6v6's. There used to be a seller on eBay or Amazon. They sound great to my old ears.
« Last Edit: May 29, 2023, 11:14:27 AM by adeep42 »
Offline joegibney
Reply #7 on: May 29, 2023, 12:27:51 PM
I was looking at the metal tube. Reasons for not using, got too hot. Kind of silly, just don't touch it.
Reply #8 on: May 30, 2023, 04:48:04 AM
This is indeed a silly reason.  The 300Bs and 2A3s in our amps get much hotter.
Offline joegibney
Reply #9 on: May 30, 2023, 06:44:56 AM
Can't wait till Western Electric builds a 2a3. I found some new in the box 6v6 cans.
Reply #10 on: May 30, 2023, 08:44:53 AM
Western Electric is very unlikely to make 2A3s.  There are still a zillion RCA, Sylvania, and GE 2A3s floating around for reasonable prices relative to spending $1500+ on WE ones.
Reply #11 on: May 30, 2023, 09:24:16 AM
WE mostly made unique designs and seldom made a version of some other manufacturer's design. 2A3 was an RCA invention, originally a single plate tube with a proportionately higher plate impedance than the later biplate 2A3, thus creating difficulties in designing an amp to use either variant. WE made the WE275, which has more or less biplate 2A3 operating specs but has a 5V filament rather than 2.5V. So you're going to need a 300B amp to run a WE275 in order to get close to creating a "WE 2A3 amp", or to modify a 2A3 amp designed for biplate 2A3s by changing to a 5V filament supply. Yup, it gets very confusing.
FWIW Psvane makes a supposed 'WE275 type' tube with a 2.5V filament. For me this is the same crime as all of the '300B' variants made in the past that had different specs than a WE300B like higher plate dissipation and higher filament current and voltage. If it is a different tube, just naming it the same does not make it any closer.
Offline joegibney
Reply #12 on: May 30, 2023, 10:23:52 AM
I was just hoping for the 300b with 2.5 filament. They are half way there.
Reply #13 on: May 30, 2023, 01:20:32 PM
It won't give you any more power in a 2A3 amp unless you make substantial changes to the amp itself (usually involving changing the power transformer and output iron).
Offline joegibney
Reply #14 on: June 01, 2023, 07:53:35 AM
I need to be patient with the Moreplay. I installed KT-75 coupling caps instead of stock. I do know the Russian caps take a while to break in. My Foreplay III has Aricaps, might be the Aricaps sound I'm looking for.
