Cathod bypass capacitor, and resistor.
ToneDeaf · 5986
Offline ToneDeaf
on: October 10, 2023, 10:09:02 AM
   This is the 150uf electrolytic that is in parallel with a 619 ohm ?
 Can this capacitor value be upped? I have been looking, but can't find a Nichicon fine gold in 150uf's. Can it be replaces with a 220uf cap?
     Is the resistor in parallel with it. It's 619 ohms. Is it a metal film or a carbon film ?
     Thank you all.
Reply #1 on: October 10, 2023, 12:09:06 PM
Yes a larger capacitance is no problem.
Online Paul Birkeland
Reply #2 on: October 10, 2023, 12:29:17 PM
Metal film.  It is mostly out of the signal path since the capacitor is across it.
Offline Tom-s
Reply #3 on: October 11, 2023, 09:04:09 AM
I've replaced the cathode resistor bypass caps with Jupiter's wet electrolytics 250uf with good results.
