Measuring Resistors In Circuit
Toys4Boys · 28384
Offline Toys4Boys
on: October 25, 2023, 06:43:29 AM
I was foolish enough to solder at extreme temp and apparently cooked some components. I am trying to go back through the parts to see which need to be replaced and have a couple of questions.
1. If a board was completed and voltage tested correctly that would be proof(?) that the components are good?
2. When I test various resistors in circuit I get an open circuit, touching he 2 legs of the, I assume that means it is cooked?
Offline Toys4Boys
Reply #1 on: October 25, 2023, 07:07:53 AM
One problem is a cheap multimeter, in the resistance setting some resistors show open, but when I set it to "Auto" mode the same resistor measures fine! Still I believe that I cooked some resistors so the previous questions are still of interest.
Reply #2 on: October 25, 2023, 11:39:02 AM
If it works, the parts are fine.
If you get a good reading automode and open in manual mode you have probably set the meter to too low a manual range for the value of the resistor under test.
Reply #3 on: October 25, 2023, 05:15:03 PM
As components go, resistors are pretty tough. Unless they are visibly discolored they are probably okay...John
Offline Toys4Boys
Reply #4 on: October 29, 2023, 12:26:58 PM
I'm starting to think the only issue that I had was my multi-tester, oh well a bit late now. One thing that I could use some clarity on is the use of "0 Ohm" resistors?
Reply #5 on: October 29, 2023, 02:15:30 PM
It's a lot easier to use the 0 ohm resistors as jumpers than to strip pieces of teflon coated wire that are cut that short.
Offline Toys4Boys
Reply #6 on: October 29, 2023, 03:27:24 PM
Sweet! Actually quite clever! Now all I have to do is fix what I broke   :'(
Offline Toys4Boys
Reply #7 on: November 03, 2023, 07:33:55 AM
Well, apparently the problem that I experienced had very little to nothing to do with me, the problem is indeed the piece of c##p
Assark 6000 meter! This caused me quite a lot of consternation and time, in the "Resistance" mode it shows nothing measuring either a 47.5 or 475 ohm resistor, but in "Auto" mode they read as to be expected. I just confirmed this with 4 new resistors sent by Eileen.
Reply #8 on: November 03, 2023, 07:40:57 AM
Back for Vsac 2006, I put together a little amplifier design/building workshop class with PJ, and as part of the class I bought four pocket DVMs from Radio Shack to give to the class participants.  Not a single one of them worked reliably, and I had to run up to the Bottlehead demo room to take all the meters Doc. B had laying around to keep the class going!
Offline Toys4Boys
Reply #9 on: November 05, 2023, 03:08:56 AM
Doing my voltage checks I'm running into some problems  on the right side of the C4S board, OD measures 140V, OKA 138V, OKC is not reading voltage. The left side is w/in tolerances.
Reply #10 on: November 05, 2023, 03:54:50 AM
What does your meter actually say at OKC?  0V is a valid measurement.  A lot of Eros repairs I get with similar problems just have missed solder joints on that center board.
Offline Toys4Boys
Reply #11 on: November 05, 2023, 08:02:54 AM
I don't read any voltage at OKC.
Offline Toys4Boys
Reply #12 on: November 05, 2023, 10:23:28 AM
In Auto mode it jumps around to resistance, in DC it does measure 0.
Reply #13 on: November 05, 2023, 10:40:39 AM
I would look for solder bridges or debris shorting pins on the bottom side of the PC board.
Offline Toys4Boys
Reply #14 on: November 06, 2023, 04:46:11 AM
I have gone over the board, soldered any questionable connections, checked for bridges but the right side is still not right:
IA 217V In range
OA 206V A bit high
OC 57V Low
OkA 62 Low
OkC .07V(?)
