Ohm switch mod
Rob C · 31475
Offline Rob C
on: November 24, 2023, 12:17:01 PM
Hello again, I would like to install an ohm switch for the paramount. I have the manual and will see in there what will help me. But any wiring diagram would help. What perticular switch and wire should I use? Thank you.
Reply #1 on: November 24, 2023, 06:25:07 PM
I believe I have a diagram; I'll be back in town Sunday and will look for it.
Offline Rob C
Reply #2 on: November 24, 2023, 06:42:47 PM
Awesome! Have a great weekend!
Offline Adrian
Reply #3 on: November 25, 2023, 02:48:49 AM
I performed a similar mod to my S.E.X 3.0.
I posted this mod under the S.E.X. forum.
It is on page 7 dated January 25.2021, titled "4-8 ohm switch".
There is a diagram showing the wiring of the switch and pictures of the connections for the S.E.X. amp.
This isn't a Paramount (I also have a pair of these), but it may give you some guidance on how to proceed.
Adrian C.
Offline Adrian
Reply #4 on: November 25, 2023, 02:56:08 AM
To clarify, you could use the same switch on both mono blocks.
You would only utilize half of the contacts, though.
Adrian C.
Reply #5 on: November 25, 2023, 04:46:02 AM
The pinout and winding design of the OT-2 (SEX and Stereomour) is different from that of the OT-1 (Paramount), and the switch arrangement is thus also different.
The OT-3 (Mainline) and OT-5 (Kaiju) are also unique to themselves.
I will try to document the various options, but it may take me a few days.
Reply #6 on: November 25, 2023, 06:08:11 AM
Here is PJ's schematic for switching the OT-1.  I believe he intended it to use a 4P3T rotary switch per chassis, which is a standard part that we have tons of, but a 2P3T switch would also work.
Offline Rob C
Reply #7 on: November 25, 2023, 06:26:09 AM
Is that schematic the final info? I definitely want to understand the wiring 200% before I go and mess with the opt.
Offline Rob C
Reply #8 on: November 25, 2023, 07:18:14 AM
Also I doubt I'm going to utilize the 16 ohm tap so double throw double pole?
Reply #9 on: November 25, 2023, 07:24:09 AM
Yes, that's the diagram I was going to look for - thanks for finding it!
It was my intent to use the 4-pole switch, wired as two 2-pole switches in parallel to make a 2-pole switch with lower resistance and better reliability. The switch on hand was used as a preamp input selector at much lower current than the power output produces.
Reply #10 on: November 25, 2023, 07:26:32 AM
That should work well. Most DPDT are rated for 15 amps so there is plenty of current-handling capability.
