denti alligator · 26674
Check the wiring on your balance pot.
It looks all good now.
Can you post photos of the selector switch and tape RCA jack wiring?
The black wires on the selector switch are grounds. The white wire is L+, the red wire is R+. You have a black and white wire connected on your selector switch, which isn't right, so you need to swap that pair at the tape output to correct for that.
Ah, I see that. But will that also correct the other output?
