Bottlehead Kits
Stereomour II
DC filament polarity quesstion.
Mucker
174
Mucker
Sr. Member
January 22, 2024, 11:05:05 AM
I do a bit of researching of the forums here and came across a thread in the Kaiju forum about when using the DC filament to wire the tube sockets at different polarity and then swap the tubes annually. Does this apply to Stereomour and how important is this? There is no mention of it in the DC filament manual so I assumed it to not be critical. I know the Kaiju is 300B but it seems that 2A3 would be the same??? Thank you.
Last Edit: January 22, 2024, 12:21:43 PM by Mucker
Global Moderator
Hero Member
Re: DC filament polarity quesstion.
Reply #1 on:
January 22, 2024, 01:22:20 PM
Yes, the same theory applies.
No, it's not "critical" in either amp, but the effect is about half as much in the 2A3 amp, since the filament voltage is half as great.
Mucker
Sr. Member
Reply #2 on:
January 22, 2024, 02:41:29 PM
Awesome. Thanks PJ!
EDIT: I just checked my wiring and both sockets were wired the same (randomly) so ended up switching the wire pair at the board on one side.
Last Edit: January 22, 2024, 03:52:22 PM by Mucker
Bottlehead Kits
Stereomour II
