dpwoos · 1435
PJ had mentioned it in the past. There's a 249K resistor between the 0.1uF brown coupling cap and ground. You can lift the ground end, then solder in a 2.49K resistor between the free end of the 249K resistor and ground. The subwoofer out can be taken from this node. I would run a twisted pair of wires from ground and this node on each channel to a pair of female RCA plugs and let them hang from the bottom out the back of the amp just to test this out.
