Bottlehead Kits
Moreplay
Audio issue a couple of weeks after Moreplay Upgrade [resolved]
Galluch57
18689
4
5
Galluch57
Jr. Member
Re: Audio issue a couple of weeks after Moreplay Upgrade
Reply #60 on:
January 01, 2025, 04:02:45 AM
Since I have replaced the 4 transistors in that B/C section of the board, I am suspicious about the 2 LED’s that don’t illuminate. I will check the soldering joints. TY
Paul Birkeland
Global Moderator
Hero Member
Reply #61 on:
January 01, 2025, 07:50:54 AM
The LEDs are sensitive to excessive heat, so you could try replacing them for the sake of thoroughness.
Galluch57
Jr. Member
Reply #62 on:
January 01, 2025, 09:17:01 AM
I will. The two on that section of the board don’t glow. Could they possibly be the cause of my issue?
Paul Birkeland
Global Moderator
Hero Member
Reply #63 on:
January 01, 2025, 09:53:53 AM
It's very rare for one of our LEDs just just randomly stop working. Maybe I've seen that 1-2 times in 20 years. Generally there would be some other issue that takes them out as part of the failure process.
Galluch57
Jr. Member
Reply #64 on:
January 18, 2025, 02:33:07 AM
Paul -
Very happy to report that after replacing the 2 LED’s that weren’t glowing on the B/C area of the board, the voltages tested in spec and the preamp sounds brilliant again!! Thank you for all your help & patience!!
4
5
Bottlehead Kits
Moreplay
