Audio issue a couple of weeks after Moreplay Upgrade [resolved]
Galluch57 · 19184
Offline Galluch57
Reply #60 on: January 01, 2025, 04:02:45 AM
Since I have replaced the 4 transistors in that B/C section of the board, I am suspicious about the 2 LED’s that don’t illuminate. I will check the soldering joints. TY
Reply #61 on: January 01, 2025, 07:50:54 AM
The LEDs are sensitive to excessive heat, so you could try replacing them for the sake of thoroughness.
Offline Galluch57
Reply #62 on: January 01, 2025, 09:17:01 AM
I will. The two on that section of the board don’t glow. Could they possibly be the cause of my issue?
Reply #63 on: January 01, 2025, 09:53:53 AM
It's very rare for one of our LEDs just just randomly stop working.  Maybe I've seen that 1-2 times in 20 years.  Generally there would be some other issue that takes them out as part of the failure process.
Offline Galluch57
Reply #64 on: January 18, 2025, 02:33:07 AM
Paul -
Very happy to report that after replacing the 2 LED’s that weren’t glowing on the B/C area of the board, the voltages  tested in spec and the preamp sounds brilliant again!! Thank you for all your help & patience!!
