Hum and tube glowing red on my Foreplay ll
hron61 · 15932
Offline Thermioniclife
Reply #30 on: February 20, 2025, 03:37:40 AM
You can buy a 2 prong male that has 3 prong female they have a short green wire with a fork connector that you loosen the wall plate mounting screw, slip the fork under the screw and retighten thusly giving a ground to the 3 prong female. there cheap. There sometimes called cheater plugs.
Reply #31 on: February 20, 2025, 04:12:43 AM
I don't recall seeing in this thread the question "are all the components plugged into the same outlet?"
If not, give that a try.
Reply #32 on: February 20, 2025, 04:32:08 AM
Do you have any water pipes or gas pipes near your system?  Is your gear plugged into an outlet on an exterior wall?
Offline hron61
Reply #33 on: February 20, 2025, 11:01:52 PM
Only one outlet is used. Foreplay and amp are plugged into a gfci extension and the cd player is hooked up to a monster cable hts 2500 power conditioner.
TV, soundbar, and cable box,  security system touchpad, and 2 subwoofers are also hooked into the monster conditioner as well.
I tried the cheater plug early on with no luck. Outlets are ungrounded, house is 96 years old.
No water pipes nearby, outlet is mounted to a center interior wall unfortunately.
Reply #34 on: February 21, 2025, 05:33:19 AM
Do you own this house, or is it a rental?  Where the outlet is, do you have access below it?
If you have a basement below that's relatively open (typical for older houses), it may not be the end of the world to run a ground wire for just that outlet.  Even if it doesn't end up resolving your issue, it's a very good idea to do this anyway.
